Question about Haier HLT364XXQ
Haier Genesis top load washer draining problem
Some times i can use the washer fine then some loads just wont drain and even when i take all the cloths out it still won't drain until i remove all the water. Error code E1 and E2 show up on the board
Lumpy816
  • 246 Answers
SOURCE: kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Posted on Jul 09, 2008
  • 416 Answers
SOURCE: Error E2
It is drain pum error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Good Luck
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Posted on Jan 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Posted on Mar 12, 2009
  • 1294 Answers
SOURCE: kenmore front load washer wont drain gives F2 error
There is an awesome guy on fixya with this:
http://www.fixya.com/support/r622155-kenmoreelitewhirlpoolduetdoorjammed
http://www.fixya.com/support/r615354-fherrorcodewhirlpoolduetkenmore
Posted on Mar 28, 2009
HAIER ENCORE WASHING MACHINE MODEL GWT750AW WONT DRAIN
Most likely pump but could be logic board not calling for machine to drain.
Nov 20, 2014 | Haier GWT750AW 4 Cu. Ft. Encore Top Load...
My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.
EDIT: one of the mounting screws on the bottom of the tub will create a "tear" (or another word that rhymes with track) in the tub (Fixya says "The word $@#%^ is considered as profanity on Fixya. Please review your answer and try again").
I used a plastic soldering iron from Harbor Freight and cut a piece of the plastic webbing off the tub to "solder" the hole shut on the tub.
Aug 22, 2012 | Haier HLP21E Top Load Washer
Hi, I bought a Haier 8.8-lb. 1.6 cu. ft. Capacity Portable Top-Load Clothes Washer from drugstore.com two week ago. When water goes into the machine, I found the water came out from drain tube at the same...
Have you got the drain pile positioned higher than the top of the machine. If the outlet of the pipe is lower than the water level, the water will just run out. If this is not the problem then don't even try adjust or open the unit. Take it back to the dealer or you will void your warranty and it is not worth it. Let the dealer worry about it.
Feb 21, 2011 | Haier HLP23E Top Load Washer
Washing machine wont drain the water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 10, 2010 | Haier Washing Machines
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water will not drain from the washer after I run a load. I've run it a few times now to see if it will drain and it just stays stagnant. Help!!!!
check the tub to pump to drain for a blockage or kinked lines and the pump for lint,coins,etc. as a blockage will be sensed and pump wont start to drain the machine even in a static drain w/o the spin cycle
Mar 19, 2010 | Frigidaire FEX831CS Top Load Stacked...
Will not hold water ,when filling it just drains out
I just had this problem also. The reason I was having this problem was that I was letting the draining hose run into my bath tub to drain. Because of this the water was immediately draining out of the washer. So I had to hook the draining hose onto my bathroom sink to drain. By raising the hose higher,the washer filled up with water and worked just fine. Hope this helps.
Jan 24, 2010 | Haier HLP21E Top Load Washer
The water drains out immediately after starting the load.
Hello. You have one of two problems.
1. Your drain hose is too far into the drain causing a constant drain. You will need to pull it out and adjust it to where it is only in the pipe about 6 inches.
2. The hose is in the drain and tape off. If this is the case, you will need to untape it and install a genesis valve. You can get a genesis valve(siphon break) at your local plumbers shop.
Jul 15, 2009 | Whirlpool LSR5132PQ Top Load Washer
My washing machine won't hold the water when I start a load.
Jul 15, 2009 | Danby DWM99W Top Load Washer
Draining extra water
Oct 10, 2008 | Haier HLP21E Top Load Washer
Haier HLT364XXQ Logo
204 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
