Question about Numark Pro TT-2 Turntable
Pitch control not working on Numark Pro-TT2
I've had a pair of PRO TT2s for about 6 or 7 years now and they've always been great. However, recently the pitch control seems to have no effect (although the platter turns as normal). All throughout the range, the pitch remains at zero (actually slightly faster than would be when quartz locked). I can hear a small difference when I bring the control to the center (going into quartz locked mode?), but there is no significant difference in platter speed. I am proficient enough at soldering that I can replace the broken components on the board (except for the surface mount stuff), but I don't know where to get the components and I can't find parts lists, wiring diagrams, or a service manual. As well, I'm not sure how to diagnose the broken component (i.e. is there a way to test if the pitch control slider is working properly with a multimeter?). Any information you could provide would be a great help, especially a parts list or a set of circuit diagrams for the TT2s. Thanks for your time.
John K.
  • 69 Answers
Numark pro sm
Great that you posted, what is the question?
Apr 14, 2013 | Numark PRO SM-1 Mixer Professional DJ...
I need virtaul Dj LE serial number for mixtrack pro
If you bought mixtrack with serato and want to change to vdj just go to
numark.com, download vdj le plugin, disconnect from the internet, install program, run installion, when asked for serial num enter:
6JDB-UFRV-X53S4
go to configuration and disable anything that would connect the program to the web, otherr wise it will not work any more
Mar 01, 2012 | Numark Industries Numark MixTrack Pro DJ...
I have recently aquired bose 520b acoutimass panray base module. can this be connected and work with my 2 pairs of bose 901's.i use pioneer SPEC 1 & SPEC 4{ power amp/pre amp}
Don't you mean "502B"?
Specs:
http://pro.bose.com/pdf/pro/brochures/panaray_502_b/b_panaray_502.pdf
http://pro.bose.com/ProController?url=/pro/products/panaray/panaray502b.jsp
http://pro.bose.com/pdf/pro/manuals/panaray_502_b/ig_panaray_502b.pdf
Why do they call the SPEC-1 a PREamp when it seems to be an INTEGRATED AMP with speaker outputs and all?
http://sportsbil.com/stereo/spec/
I'm going to assume one of the numbered, presumably volume-controlled outputs (1,2) goes to the 901 Active Equalizer and on to the SPEC-4.
The OTHER numbered output could feed the missing Panaray Digital Controller and then, presumably, another amp but like many a 901 owner I've heard of, you COULD skip that part for the 502b and hook them to the unmodifed amps available in the SPEC-1 and see how it works out.
Jul 19, 2011 | Bose Audio Players & Recorders
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
Numark Pro TT2 turntable.
Try A New Cartrige And New Styli And Let Me Know The Outcome
Dec 05, 2009 | Numark PRO-TT2 Turntable
How to find a new platter???
htfr.com is quiet useful or look on ebay. 500s arent tht hard get equiptment for.
Mar 03, 2009 | Numark PRO-TT2 Turntable
Pitch trouble numark tt-x1
Either the pitch control is damaged, or your drive system is damaged. Unfortunately for either case, your going to need some professional assistance.
Sorry I couldn't be of much more help.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Apr 13, 2008 | Numark TTX1 Turntable
Turntable probems
Belt or belts needs replacing. Happens when they get worn. Happen a lot in the days before CD's. Fairly simple to replace if you are mechanically inclined or have some one do it for you.
Jul 10, 2007 | Numark PRO-TT2 Turntable
Numark Pro TT-2 Turntable Logo
374 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
