Question about Magellan Triton 400 Handheld GPS Receiver
Magellan Triton 400 update failed unit stuck in white screen
I tried to update my firmware using vantage point. The update failed in the middle of the update then froze my computer. It is now stuck in a white screen with the file menu but none of the options work. It will not power off with the power button and the batteries need to be removed to power it off. My computer says that is is connected but nothing seems to recognize it as the GPS. Is there a way to reset it or has the software been deleted?
  • 1 more comment
  • blewbot Mar 01, 2009
    same thing here... except mine failed at the very beginning and froze in a white screen. i also had to remove the batteries to shut it off. and now i cannot connect my gps to the computer to update, install maps, ect.
  • Anonymous Mar 03, 2009
    I have the same problem as this one. Can not seem to find a solution.
  • masood alam Mar 26, 2009
    I am experiencing same problem, did all sort of things like;
    1. tried uploading old firmware. nothing happened
    2. tried several key combination while powering on of unit. nothing happened.
    3. tried through Vantage Point. but nothing happened.
    Will some help us and save our hard earned money going into vain.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 154 Answers
Actually some bad news for you all. When you used the VP somehow you corrupted the internal software in the GPS. If the damage is done then you need to reflash the internal memory of the GPS. If the unit is in warranty .. then call Magellan.
Posted on Dec 01, 2010
Did anyone solve this problem yet
Posted on Feb 04, 2010
I have exactly the same problem with my Triton 500 - did anybody find a solution?
Posted on Dec 23, 2009
SOURCE: Magellan Triton 400 update failed unit stuck in white screen
Hey, Had the same exact problem, found a website with instructions on how to fix it. Turns out there was a corrupt file in the update, so you have to download the update directly from magellan and copy/paste into folders yourself. Anyway, here's the link--it worked perfectly for me!
http://www.gelb.com/jungleghost/Articles/Upgrade_Fails_to_Complete.htm
Posted on Jul 21, 2009
  • 4 Answers
SOURCE: Problem Appear After Update Interrupted Triton 400
You will need to send it to your place of purchase or send it to a authorised Magellan Dealer. This is due to that you corrupted the file during the firmware update process
Posted on Jun 29, 2010
support302
  • 154 Answers
SOURCE: Frozen gps magellan triton 300
The problem is being caused by a corrupt file in the internal memory. This requires a service repair to find and remove the file. Try the Jungle Ghost at jungleghost.com. They do repairs.
Posted on Sep 06, 2010
support302
  • 154 Answers
SOURCE: Unable to create DirectX device. Vantage Point will be closed.
Answer .. remove NET FRAME and reinstall the VP. XP with SP3 has exhibited this problem.
support302
  • 154 Answers
SOURCE: I have got a Magellan
Answer is already posted. Remove NET FRAME and then reinstall VP>
Each time I plug in the USB cable I get a blue screen. I am running Windows 7. I am trying to load maps onto the Triton 400.
Don't bother with the 400 on a Win7 machine even though Magellan claims it will work. I also keep getting a bad pool header blue screen on mine even though I've updated everything I could. The best thing to do is to either setup a dual boot system with WinXP and only plug it in while running XP (Don't bother with XP mode in Win7) or have a second system that's dedicated to XP and run Vantage point from it like what I run now from my laptop.
The whole problem is caused by the Triton driver and for some reason Win7 doesn't like it all that much. Vantage Point does run great inside Win7 but as soon as you plug in the Triton, that's when it all starts to screw up.
All we can do is wait until Magellan gives us a proper working driver.
Aug 21, 2010 | Magellan Triton 400 Handheld GPS Receiver
Apr 19, 2010 | Magellan Triton 400 Handheld GPS Receiver
Triton 400 will not load maps.
OK .. you could have many possible causes. The most likely is that the magellan drivers are not installed on your computer. If you installed Vantage Point you will find them under the c:\magellan drivers folder.
Now without Vantage Point being on just connect the GPS to the computer and turn it on. Then open up the device manager on your computer and you will see a PORT COM(number). Click on the properties and see if the device driver is enabled and working.
If it is not.. then uninstall the present driver and reinstall from your computer by pointing to the c:\magellan drivers folder.
JG
Sep 21, 2009 | Magellan Triton 400 Handheld GPS Receiver
Aug 01, 2009 | Magellan Triton 400 Handheld GPS Receiver
Cannot find driver for my Magellan Triton 400 to download
The drivers are in the directory c:\Magellan Drivers. If they are absent .. then you need to reinstall Vantage Point.
Jul 09, 2009 | Magellan Triton 400 Handheld GPS Receiver
May 30, 2009 | Magellan Triton 400 Handheld GPS Receiver
Magellan Triton 400 has blank white screen
The firmware update corrupted the software on the unit.
It is too complicated to fix yourself. If the unit is out of warranty, the JungleGhost at jungleghost.com has a repair service. Go to http://www.jungleghost.com/repair_service.shtml
Mar 29, 2009 | Magellan Triton 400 Handheld GPS Receiver
Udating sofware and now it is stuck on a white screen
You have corrupted software in the internal memory. It is too complicated to fix yourself. If the unit is out of warranty, the JungleGhost at jungleghost.com has a repair service. Go to http://www.jungleghost.com/repair_service.shtml
Mar 28, 2009 | Magellan Triton 400 Handheld GPS Receiver
Magellan Triton 400 Handheld GPS Receiver Logo
1,474 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
