Question about Sony DVP-NC800H DVD Player
Best set up for DVD/CD, TV Receiver
Is it better to run my DVD/CD player through the TV or through the receiver and then the TV? All products are Sony. I have cable TV
  • 10,865 Answers
Both the TV and the receiver have a tuner. One may get a better picture for you than the other. The only way to determine this is to try it each way and decide for yourself. Generally speaking the receiver will give you better reception, but not always.
Posted on Feb 16, 2009
  • Joe Hogan Feb 16, 2009
    please rate my answer as a fixya! thanks.
How do I connect my NAD cd-player?
If you have a receiver with a digital rca input, buy a good quality coaxial cable and connect it from the digital output of you cd or dvd player. The digital/analogue converters inside the receiver are almost always better than the ones in the cd player. If running cd to a stereo receiver, just use a good quality pair of rca interconnect cables. Red is right, White is left.
Jun 09, 2016 | NAD Audio Players & Recorders
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
Conection to tv
You mentioned DVD/CD "Receiver" ? Is it a receiver or player?
A player has Audio Out connecting points where you attach RCA cables to it and run the cables to the RCA Audio IN on the TV.
Dec 25, 2013 | Pioneer Televison & Video
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
I want to hook up my bose speaker systerm to my new vizio tv
Real easy, get a RCA audio cable (red and white ends) that is long enough to go from the tv inputs to your receiver inputs. Plug one end into the audio out on the back of your tv, then plug other end into input on your receiver (tv, cd or vcr). Now everything going to tv will output to receiver also. You may have to go into the TV menu and under audio, set audio output to fixed. Then you can change the volume on your receiver which is best way to go.
**Advanced** If your TV and receiver has optical capability you can use an optical cable instead.
Good luck,
Mar 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Too many Cables??
Firstly, let me address audio cables. Optical audio is the same (essentially) as a coaxial digital audio cable, just in a different form. Since you just purchased a Bluray player, you'll see an HDMI out on the rear. This is a high definition video and audio cable rolled into one (however it looks like your receiver does not support this). I would recommend running an HDMI cable from the Bluray player right to the TV, then run an optical audio cable (or coaxial digital) from the TV to the receiver. This will give you the best picture on your TV, and the best available sound through your receiver.
Depending on your DVD player and Bluray player, you might want to consider using just the Bluray player for DVD's and Bluray discs. If your plasma supports 1080p (or really anything better than 480i), you would most likely get a better picture out of DVD's since the Bluray player will upconvert the video to the better signal (of course this depends on your exact model of Bluray player). This will help to eliminate some cabling also.
Other than that, you're not going to eliminate much more cabling. If you really want to get tricky with it, pick up some split loom wire management and wrap them up with that. Be sure to run the power and signal wires separately though! Best of luck, and hope this has helped.
Dec 20, 2007 | Audio Players & Recorders
Sony DVP-NC800H DVD Player Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
