Question about Mitsubishi WT-42311 42" Rear Projection Television
Red convergence can be adjusted up and down, but not left or rt.
I replaced both IC's (STK392-110) no change. What else could it be.
  • d7192003 Feb 16, 2009
    Model number WT-42311 rear projection. I checked the resistors in front of the IC's and they all read the same. Are these the bias resistors? Does the pcb need to be removed to read the pico fuses?
  • 4,234 Answers
Check in the area for amsll pico fuses or low valued resistors. These are often damaged when the ICs fail. Please verify your model number so we can provide additional details.
Thanks,
Dan
Posted on Feb 16, 2009
I have a sony big screen kp57wv600 and the picture looks like I need 3D glasses. The pictures has a green and red hallo all around the outer picture. The picture is clear in the center and goes out and is...
Sir the problem of your tv is the convergence to narrow the problem try to adjust first the convergence settings using your original remote go to setting menu then to the convergence setting, you can adjust the red and blue convergence, you should be able to adjust the red and blue left, right and up, down you should align the red and blue to green but if you cannot move them far enough or if you cant move them in any direction the convergence IC is already defective replacing this IC will fix the problem, you will find this convergence IC attach to a large aluminum plate this aluminum plate is the heat sink. It is easy to locate if you remove the back cover of your unit be sure to unplug your TV
this is the convergence IC if you remove this try to observe also if there is a cold solder or dry joint because sometimes this cause your convergence to malfunction observe the solder part of the convergence.
This is a cold solder or dry joints you can fix this by resoldering using a soldering iron, soldering lead, and desoldering pump but be sure not to connect separated pins it may cause much damage to unit if accidentally solder together. To replace the IC convergence try to check this link http://www.tvrepairkits.com/xcart/product.php?productid=19971&cat=1538&page=1 hope this helps good day and best regards.
Sep 23, 2011 | Sony KP-57WV600 57" Rear Projection...
My tv is a magnavox and we bought it about 3 years ago and it is now showing like a double picture the color is hazy and pinkish looking the model is 51MP392H/17
The problem of your unit is the convergence. Try to adjust it using the original remote control in the setting menu, then goto the convergence section adjust the red and blue convergence, you should move red and blue UP, DOWN and LEFT or RIGHT, if you cannot move them far enough the convergence IC is defective, replacing this IC will restore the original setting of your tv. This convergence IC is attach to a large aluminum plate it is the heat sink this IC has a marking of STK-#### followed by numbers, remember be careful when replacing this IC you may accidentally tampered or damage the PCB and cause much damage to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards. Try to check this link for the convergence http://www.google.com.ph/search?q=convergence+ic&hl=tl&sa=X&tbm=isch&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=798&bih=472&ech=1&psi=JZdtTvDCPIe4iAe72sTABA.1315804977740.3&emsg=NCSR&noj=1&ei=MpdtTpa4OKKSiQfBpcjGBA
Sep 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
I am able to adjust all the color convergences except red. Won't line up. Any helpful ideas would be appreciated. Also, if I have to replace an ic, typically how much does that tend to cost? Can I do it or...
The two convergence IC's need to be changed on the convergence board, and also check the low ohm resisters that might have change resistance on the convergence too. The red and blue should move up and down and left and right. The green is sationally.
Nov 11, 2010 | Philips 60PP9202 60" Rear Projection...
I get a ded line or red underline, or shadow that does not follow
3 d effect is most likely bad convergence Ic---think this set has in the customer menu an option to adjust--if it does go there----if red or blue will not adjust in any direction(up and down or left and right) you need to have both convergence Ic's replaced and then the set adjusted.
Jul 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Help, Help, Help! Mitsubishi 73" red convergence fiasco
Thats the time you need to replaced the convergence IC.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry and fuzzy images .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and cannot be adjusted this is the symptom for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Mitsubishi WS-73907 TV
Convergence
u could try changing the convergence ic if that is not it then u have to go in to the back door of the eprom to set but i think pansonice u need a service remote to get in. i hope this will hp marty
Jul 17, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
