FixYa.com
Tags:
Acer Aspire  5050-3242  PC Notebook
ACER laptop 5050 (by 5 users)
posted by jb_blondie on Aug 01, 2007
when I switch my laptop on I get a message saying "operating system not found"
Comment by jb_blondie, posted on Aug 02, 2007
Thanks for your advice, tried everything... sadly it seems to be the actual physical hard-drive, but it is still under warranty so am returning it today. Thanks again.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by jahbiggs, posted on Jun 22, 2008
i want to reinstall xp on my computer but it is saying os not found
Comment by Guest, posted on Jun 22, 2008
acer 5050
Comment by Guest, posted on Jun 01, 2008
i lose my administrator
Comment by lilybee, posted on Feb 09, 2008
I have a Acer Aspire 5050. It started two days ago when my laptop accidentaly fell and now the operation systmen of xp doesn't work. I use the recovery disk and it got worst now it says that the NTDLR is missing. And the recovery disk give's me error all the time. I open the hardrive compartment and nothing seems wrong. I put on again. Same problem.
Best Solution
FixYa! (100)
mrogers
Rank:Wiz Wiz
Rating: 81%, 99 votes
Its NOT the hard drive itself.
Its the master boot record on the hard drive that has failed.
The master boot record is like an index or an address book of a hard drive. It hold records of whats on the hard disk and the physical location of files and directory's.
What most likely happened was the computer was NOT shut down correctly and a power serge corrupted the master boot record or someone accidentally or purposely deleted files they should not have.
If you are not able to follow jmorgan123 advice, the easiest way to fix this is to re-install windows using the recovery disk (operating system cd), HOWEVER you WILL loose all your files on your hard drive as you will need to reformat your drive during the re-install.
If you are unsure how to install windows
put the system recovery disc in the drive and follow the on screen prompts.
If you still can get your computer working after you try a re-install of windows, maby your best bet is to return the computer under the warranty.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 01, 2007
Thanks for Trying (70)
jmorgan123
Rank:Guru Guru
Rating: 87%, 532 votes
Your computer is not recognizing the hard drive.
Hopefully your have your operating system cd.
Put the CD in the drive. Boot from the Windows CD. It has three options: Recovery Console, Repair Installation, and Normal Installation.
Try the Recovery Console. It should scan your hard drive and detect Windows installations, and ask you which one you want to examine. It may ask for your administrator password. Then it should give you a C: prompt. Get a directory (dir) and if it looks okay (no garbled text) and reports the free space, things are probably okay.
If you get to this point with no trouble:
At the C prompt, say FIXMBR <enter>. I'm not sure what kind of output it gives, but it should rewrite your master boot record. Then at the next C prompt, say FIXBOOT then enter. That'll rewrite your partition boot record. The two boot records are the first steps to booting the operating system.
Now, try booting without the CD. If it boots, then the FIXMBR and FIXBOOT worked. But I suspect you'll have the same error.
Comment by jmorgan123, posted on Aug 01, 2007
If that works and you continue getting the same error, boot from the CD again. Press 'Enter to Setup Windows now' or some such. Then, you want to perform a Repair Installation.
Don't worry, this won't remove or delete any of your files or settings. It only replaces Windows OS files.
Rating Locked! (?) jb_blondie has rated this solution as Thanks for Trying
Can you Help with these PC Laptops problems?
Acer Aspire 5050-3242 (LX.AG30J.012) PC...
internet explorer dont work
when i hit shortcut internet... Answer This...
PC Laptops
please help me agian
please help me about my... Answer This...
PC Laptops
problem vith lap-top
Several things you need to... Answer This...
PC Laptops
camera assistant software
I can't find camera assistant... Answer This...
PC Laptops
microphone problem
hi my name is anil my laptop is... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
