Question about Procom ML060HPA Heater
HEATER AND PILOT GOES OFF AT TIMES
Pilot lights ok - heater may cycle on\off for several hours and then all of a sudden heater goes completely out and so does the pilot - it lights ok when you try to light it - pilot has blue flame when on - but whole thing goes out at time
  • 51 Answers
Sounds like your oxygen depletion sensor is shutting your unit off. The problem with fixing your unit is that it may cost you the same to purchase a new one (assuming you pay someone to fix it).
Posted on Feb 17, 2009
Apparently there was dust or debris in the lines - The gas company sent out a man and he blew out the line to the pilot - hopefully this will continue to take care of the problem
Thanks for your help
Glo warm pilot works but heater goes off after about one minute
THE HEATING ELEMENT MAY NEED TO BE REPLACED. USUALLY IT'S CHEAPER TO BUY A NEW HEATER THAN TO REPLACE ANY PART IN ONE.
Feb 02, 2015 | Heating & Cooling
Propane wall heater
Clean pilot , Then check thermocouple if it is not staying alight .
May 03, 2017 | Heating & Cooling
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
Set on pilot to lite heater. Once i release valve pilot goes off. This happened several times.
the pilot flame should sweep about 3/8" to 1/2" of the thermocouple. if this is happening then your thermocouple is bad and need to be replaced. pilot should be blue in color and be a sharp flame not lazy and yellow tipped
Jan 06, 2011 | Williams 3501922 (NG) Gas Compact Heater
Pilot light goes out
if the unit goes thru the cycle of heating the water and when temp is met pilot goes out you need to replace the entire temp control if pilot goes out as soon as you release the pilot button you need to replace the thermo couple little copper wire the goes from regulator to inside burner...check for 800 number on front of w/h for warranty info..as regulator can be expensive
Dec 09, 2010 | Reliance Natural Gas Water Heater Control
The pilot will not stay lit.
No, the pilot light fine now. It will just suddenly go out. It may be fine for 12 hours and in the middle of the night it goes out.
Dec 11, 2009 | Coleman (5040B750) Patio Heater
I am working on an older Williams gas wall heater. Pilot lights, heater comes on- after 1 hour cycles off, kills pilot light. one year ago installed new gas regtulator. DJWilson djwilson10@juno.com
You have some limit switches located around the unit one high one or two around the middle one of them is opening and not closing. You need to take off the cover and locate the limits undo the wires and ohm them out you should have complete circuit now the one that is open when you find it is bad and needs to be replaced with the same rated heat temperature as original. Your t-stat goes through these limits and one open would kill the whole circuit. Let me know how it goes. ken
Dec 06, 2008 | Heating & Cooling
Pilot going out
sounds like a bad thermostat.I am not to familiar with this problem.
sorry i could not be more help
Nov 23, 2008 | Heating & Cooling
Pilot will not light
The Pilot indicator will appear to line up with the arrow on the base, and even push in as though allowing gas to flow, but if it is just 1mm out of alignment, no gas will flow. So the solution is to move the valve in the Pilot mode slightly in one direction or the other to see if/when gas flows.
Nov 06, 2008 | Williams 1403622 Gas Compact Heater
Procom ML060HPA Heater Logo
279 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
