Question about HP Compaq nc6000 Notebook
Not Powering up.
Hi I have a problem with my HP laptop.
When you power it up you hear the fan kicking in ,and then it cuts out.
Some times it will run untill you sign in then it will cut out on screen,it goes blank, but it will still run on.will not switch off,need to take battory out.
Please could any one HELP SORT THIS OUT ? THANKS.
  • 51 Answers
Hello there
I understand your Notebook is not powering ON. You can perform power drain to resolve the issue.
1) Perform power drain. Follow below steps for Power drain.
a) Shut down the Notebook and remove the battery completely from the Notebook.
b) Press and hold the Power button for 30-50 seconds.( This will discharge any static electricity in the picture tube)..
c) Connect the battery and switch on the Notebook.
If the problem still persists log on to 24X7 chat support by clicking the below link or pasting it in the address bar of a web browser.
Posted on Feb 17, 2009
  • Colin May 29, 2011
    The most usual cause is bad connections on the Maxim 1987 chip
How does a person fix a black screen on an hp laptop that has windows vista in safe mode.
Plug an external monitor in. Power up the monitor and then power up the external screen.
Dec 06, 2015 | HP Computers & Internet
Hp laptop fan kicks on high then functions hesitate until fan slows again
clean the fan and the vents and apply new thermal paste on the processor.
Sep 07, 2012 | HP G60 Notebook
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
1995 Ford Windstar wont start win the cooling fans are on
If cooling fans are running then the PCM is not powering up. Check or replace the PCM relay in the under hood fuse panel
May 12, 2009 | 1995 Ford Windstar
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
HP Pavillion dv9720us Notebook PC will not come on
i got mine fixed at r-tech for 160 dollars, they fixed my motherboard (818) 347-1100
Jun 25, 2008 | HP Pavilion dv9000z Notebook
Hp pavilion no power
Hi pacman69,
I had the same problem for my customer here.Its the VGA chip
on the motherboard.But I know this model aboard they did and extended warranty.Here is the link you can get more information.
But in my country, I check there is no such support.
May 11, 2008 | HP Pavilion dv9000z Notebook
Won't power up
Did u hear any beeps???
Oct 28, 2007 | HP Pavilion zd8000 Notebook
HP Compaq nc6000 Notebook Logo
195 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
