Question about OEM Systems Vehicle Parts & Accessories
Car alarm wont turn off
I have a car fitted with a Clifford GS 470 alarm. The car was not started for about 5 months and the battery went flat. When I put in the new battery the alarm would not stop. I tried both alarm remote controls and put in the valet code (I think it is the right one) and the alarm will not stop
  • 265 Answers
Try changing the batterys in the remotes mate
Posted on Feb 16, 2009
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Clifford alarm
check the internal battery of the alarm as it may be getting low on charge.
May 30, 2013 | Vehicle Parts & Accessories
Clifford intelliguard 950. Won't work properly
Find the manual that came with the system, it will tell you how to reprogram the system after a battery change, these systems are famous for killing batteries if the car is left sitting and not started.
Oct 14, 2012 | Cars & Trucks
My car was running perfect until i let it sit for around six months and my father went to start it but it wouldnt start so he but the battery on the charger and still wont start it has a pro starter on it...
The most likely one is the battery went flat causing brown out of the ECU unit or the boy racer add on .I get no end of problems caused by add on so called car alarms from the long term airport parking lads and 9 out of ten times even after removing the add on alarm its still will not start and invariably end up with either a dealer fitted new ECU or one from a scrappy with the key chip and the transponder .
Apr 25, 2010 | 1994 Chevrolet Cavalier
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Looking for clifford alarm manual,did not use the car for 8 months,the sound on the alarm went,does work ,lock unlock but no sound ,maybe easy repair????any ideea?thx
look in the phone book, (YES) the phone book and see if there's an alarm dealer around you that is an authorized dealer for clifford they should be able to assist you.
Sep 20, 2009 | Car Audio & Video
I have a car fitted with a Clifford GS 470 alarm but I cant get the alarm to stop. The car that this alarm was fitted in has not been started in 5 months and so the battery ran flat. I replaced the battery...
you might have to replace the batteries in the remotes. The reason why the alarm is going off because once you plug power back to the alarm brain it sets the alarm off and the only way to make it stop is to hit the unlock button the remote. Make sure all connections on the alarm brain are good and try changing the batteries in the remotes. also might have to reprogram the remotes to the brain if it has been sitting for awhile.
Feb 16, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
619 people viewed this question
Top OEM Systems Vehicle Parts & Accessories Experts
xxxxxx xxx
Are you an OEM Systems Vehicle Part and Accessory Expert? Answer questions, earn points and help others
