Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Lower oven does not work. Ind. light comes on but no heat
Our Kenmore works fine except lower triple task oven will not produce heat. indicator light comes on when dial turned, but no heat.
  • pfeiferonthe Feb 16, 2009
    there are two elements in the bottom drawer unit. Neither work, could the dial be malfunctioning? Is there a way to clear any signal from the self cleaning if this is a problem, or could the thermostat be bad and not allow the oven to heat?
  • Anonymous Feb 21, 2009
    Up can set the oven and start the pre-heat it starts to workfor about 1min. then stops.  HELP!!
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Posted on Feb 16, 2009
I have a Lamona LAM3200 oven, recently the the oven indicator light has been coming on when the oven itself is off? What could be wrong?
sounds like you have a defective oven controller. Be careful, this can be a fire hazard. I suggest you call a appliance repairman.
Dec 30, 2014 | Ovens
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Ovens
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Pulling lower coil and big spark came flying out of oven backwall
Have you had a chance to fix it yet ? The wire has probably come off or burned off keeping it from working. Feel the element to see if it has any rough spots in it. This will indicate it is burned up on the inside.
Jan 28, 2009 | Kenmore 47783 Electric Single Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Oven is not working
No, the door is able to be opened, light works. No press switch works on the pannel and F 7 shows up on the scren along with time. I even can not fix or change the time. ANd, F7 goes away after pressing clear and comes back by itself after a while in both upper and lower. This is a Kenmore wall double oven. I do not know the model name, but it is not much used in teh last 5 years. Looks like a new one.
Jul 19, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
280 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
