Question about Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305 keeps turning off
I have been using my garmin for quite sometime. For some reason it turns off one or two times during my hour walk. It is driving me crazy. It is not a battery is low problem so I just can't figure it out. I walk almost the same route everyday but I don't think it is turning off necessarily in the same exact place. Please help.I have the same problem. Todt, here is my additional dummy question: How did you manage to open the Garmin 305? Thanks!
  • akkson Feb 16, 2009
    Thanks. The warranty is over anyway. Here's my actual question: Any insights on how to actually open the Garmin device?
  • 6,784 Answers
If this unit has been stored in a trunk or in high temperature situations, this can cause this type of situation to occur. this may be permanent damage.
Posted on Feb 16, 2009
  • Michael Masters
    Michael Masters Feb 16, 2009
    1. Locate the circular battery cover on the back of the heart rate monitor.
    2. Use a coin to twist the cover counter-clockwise so the arrow on the cover points to open.
    3. Remove the cover and replace the battery with the positive side up.
    4. use a coin to twist the cover clockwise so the arrow on the cover points to close.
  • Michael Masters
    Hi again, i have provide a link so you can have access to the owners manual. Click here to access the manual.
    Sergeant:
  • 250 Answers
Gps information in detail with troubleshoot
http://gpsinformation.org/dale/Palm/iQue3600.htm
the model is different but the system of disassembling is very same, do only if you r familiar with this technical jobs.otherwise it can be damasged.if taken risk.the instructions are mentioned .
  • Garmin Master
  • 13,433 Answers
Possibly a loose connection would need to open it to inspect it, are you sure you want to open it? it will void the warranty if its still intact and in warranty.
How do i reset my garmin forerunner 305
Here is the link to the manual it will explain how to reset on page 6.
If your device has locked up during use, you can reset your unit by pressing the "Mode"(reset/lap) and "Power" buttons at the same time. In addition, please make sure that the device has the latest software version available. Go to the garmin web site and install the newest web updater.
Thanks for using FixYa
http://www8.garmin.com/manuals/984_OwnersManual.pdf
Jul 15, 2011 | Garmin Forerunner 305 GPS Receiver
My Garmin Forerunner 305 quit working at mile 15-ish during my 26.2-mile journey. There was a faint sound but the screen was blank. It doesn't seem to charge. I tried soft reboot by pressing on the MODE...
Try hard reset.
Hold mode + start for ten seconds (device off beforehand). Keep holding then pulse push lap/reset button.
You get a screen asking to return to default settings. You will loose all your data, but device should work then
Sep 26, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Ive not had my garmin 305 long, it will not charge or turn on.
This might just need a reset. To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version available by downloading and running the WebUpdater program. To update the software, please use the following link:
http://www.garmin.com/products/webupdater/
Sep 21, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin 305 forerunner
you can't. If it is getting softer and softer the speaker may be on it's way out.
See this link for a possible reason (bottom of the page).
http://ctorunner.googlepages.com/dismantleforerunner205
Sep 01, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305 won't turn off and keeps ringing .
You can reset the unit by pressing the and holding the mode and lap buttons simultaneously. This will power it off.
Jul 24, 2009 | Garmin Forerunner 305 GPS Receiver
I have the forerunner 305 - it is not taking a charge and won't turn on??? I have only used it 4 or 5 times
Plug in the garmin to the wall.
Hold down the reset and mode buttons for 3 seconds.
Try to turn it on or look for the "charing in process" words.
Jan 17, 2009 | Garmin Forerunner 305 GPS Receiver
The problem is that the connectors inside the garmin are not consistently touching. You need to open the unit and bend the little prongs on the screen side out a bit so that they touch the connectors on the other side of the unit when closed. I did this with my unit and it touch car of this.
Jan 14, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305. Problem receiving activities and courses
This turned out to be corrupt data on my machine. I opened the Garmin traing center, backed up all the courses then deleted them inside the Training centre. I then received from device and all was okay.
Jan 12, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
133 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
