Question about GE 24 in. Profile PDW9280JSS Built-in Dishwasher
Constant Beeping - No Control Panel Lights
GE PDW9280J100SS Dishwasher, approx. 6 years old. We had a power failure for 12 hours and when power was restored the DW emits a constant beeping tone with no LED's on the control panel. Being an electrical engineer myself, I figured the control board had taken a power surge so I ordered a new one. While waiting on the board, I checked all other components and could find nothing wrong. Installed new board and have the same problem as before. Continuous tone with no control panel LED's. Voltage is good and this tone is emitted even with nothing but power plugged into the control board.
Any help before I buy another dishwasher?
Thanks
Ricky
  • 1 more comment
  • JKKern1 Mar 08, 2009
    I gave the same issue with a GE profile PDW9200J00BB about 5 to 6 years old. The power to the outlet it is plugged into was cut for 4-6 hours and when we turned it back on it emits a continuous beep noise and has no lights on the control panel
  • Anonymous Apr 13, 2009
    I am having the same problem. After a brief 3 minute power outage the washer is emitting a continous tone and will not do anything. Model #PDW9280.100SS. Any help sure would be greatly appreciated.
  • tscott349 Apr 24, 2009
    We had a power suge too and have the same problem. Ordered a new board and it still doesn't work and it is still beeping! Our's is 5 years old. It happened on April 14, 2009. Help anyone?
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
hemantraj
  • 638 Answers
SOURCE: our dishwasher, GE model #
its a normal problem every dishwasher comes to this stage after some period .it is the problem of all the food remains stuck to your unit in the corners for a long time in your unit .its the time for a servicing required for the unit.a plumber is good idea.but a professional service technician will do it in much better way and also provide you the garrantee for near about six months if the same problems presists.and that to not more than his service charge he will charge you.
rate the solution as "FIXYA" if you get helped by it.thank u in advance. wish u success .bye
Posted on Jul 01, 2008
  • 54 Answers
SOURCE: constant tone, no display lights
You need to replace the computer
Posted on Jul 04, 2008
  • 43 Answers
SOURCE: GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Posted on Oct 16, 2009
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
GE Dryer possible control board problem
Get another one with a good name and sell your old one on eBay and get a good price for it.
Jan 12, 2015 | GE Dryers
GE gld5708vbb flashing lights locked controls
It is possible that since the neutral was bad it could have made a surge on the power and caused the processor controller to fail. It is also important that this must be confirmed to be corrected by checking with a larger load like a heater being switched on and not causing any voltage drop. If so the line is clear. Also make sure that the ground - Earth- is also intact.
The program has reset because of an error and it must be confirmed to be within or outside the washer. So remove plug and test this terminal with a large load test to confirm that the outlet is OK.
If so check the panel connections or is best to refer back to the dealer as the replaced panel will have a warranty.
Please take second opinion before the board is removed.
Jun 28, 2012 | GE 24 In. Black Built-In Dishwasher -...
Pdw 9800 jooww When power came on after outage, touch panel doesn't work and there is a constant beeping noise.
Try pressing two control buttons side by side in the center of the panel. The result will light all the buttons on the panel. A test mode will follow before it resets itself.
Sep 24, 2010 | GE 24 in. Profile PDW9800J Built-in...
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
Had the power go out in our house. When power
hello. thanks for choosing fixya. honestly I do recommend that you get a new one. By the time you get your current one repaired you will have almost as much money in it as a new one and you will miss out on lots of things the new ones offer now such as: much more efficient use of power, much more efficient use of water, much quieter. and a much better wash. Regards, J.
Nov 05, 2009 | GE Profile PDW8400J Built-in Dishwasher
I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Aug 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE ZBD6880KOOSS
This is an unusual failure. The humming could be a motor (or valve) that has power but isn't moving. But that doesn't explain the (absence of) lights on the control panel. I suggest you call a professional.
Mar 31, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
GE 24 in. Profile PDW9280JSS Built-in Dishwasher Logo
427 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
