Question about Ryobi Tools & Hardware - Others
Ryobi RE600 plunge router binds on the posts
My plunge router wont plunge. Cleaned the posts and it works slightly better, but still binds up. Can anyone recommend a lubricant for the posts to ease this problem?
  • Anonymous Mar 19, 2014
    took out bit then it would not go back in wont open up enough
  • Anonymous Mar 21, 2014
    owners manual for ryobi re-60 plunge router
  • 2,176 Answers
Are you cleaning the area that contains the springs also and if so I would use something like a dry lubricant so that it won't attract more dust and dirt but we both know that eventually it will. Coat the posts with this and allow to dry and then push up and down on the motor to lube the bushings and you might have to do it again. You can also try a small amount of 3 in 1 oil but use sparingly.
Posted on Feb 16, 2009
Ryobi manuals
For which model Ryobi product do you need the manual? Many manuals are available here: https://www.ryobitools.com/outdoor/support/manuals . Just searching for Router gave a number of options. Since most fixed base or plunge routers will adjust similarly for a given style, you should be able to find some information that applies to your router.
I hope this helps.
Aug 01, 2014 | Linksys Computers & Internet
I need to find out how to get my craftsman router to plunge when the plunge adapter is installed on the router. I've lost my owners manual and can't remember how it works. Model 320.17543
To make sure that you have everything assembled correctly it would be better if you downloaded the free manual from
http://www.hammerwall.com/Download_Manual/43956/
You may have to register, but this is a free service and well worth it.
Let me know if you have any problems or further questions. Thanks.
Please rate this solution.
Jul 19, 2011 | Craftsman Tools & Hardware - Others
I just bought a RYOBI plunge router 1250W. I was trying to install the collet and it was stuck (not even half way in) so i was wondering how can i solve this problem? I mean i am affraid to take it out by...
some of your better routers the collet is fastened in with a screw, flashlight look for a screw partially out. or splines to line up. consider these thoughts and deside if maybe you have it jamed. if so reverse this infraction.
Oct 18, 2009 | Ryobi Tools & Hardware - Others
How do i use the router for lettering
Hi
You need a bit that does not have a bearing fitted to the end of it.
You can get them at a hardware store. Happy to answer any questions you may have about it. Dont forget to rate :)
Cheers
regards robotek
Jul 14, 2009 | HP Ryobi Reconditioned 2 HP Plunge Router
My Dad has a used ryobi router RE600 and there seems to be a switch for maybe speed control? is missing. We would like to find out where to purchase the part. Thanks. takertim@hotmail.com
Have a look here. and click on the parts list to open a pdf you can read. It's probably part 21 or 22, the dial or the speed control circuit module. Ryobi is always hard to find parts for. They seem to have released different models in different parts of the world, and their search database leaves a bit to be desired...
Here and here are two links to sources I've had some success with.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 29, 2009 | Tools & Hardware - Others
Cannot remove the fixed base
Are you sure the lock nuts haven't loosened and worked their way down the threaded rod to tighten the router down into it's plunged position? That's a really common thing to happen with plunge routers, but without a model number I can't give you any certain advice.
Try breaking those two nuts loose and spinning them back up the stud and see if that doesn't do it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 15, 2009 | Tools & Hardware - Others
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
Ryobi gas string trimmer won't run
I obviously posted this under the wrong category. I would post it properly, but I can't get back to where I was (or should be)
Sep 07, 2008 | Ryobi 15" Electric Factory Reconditioned...
Tools & Hardware - Others Logo
466 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Phil Rivera
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
