Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia chirping audio
I just moved to a new apartment. When I hooked up my sony bravia, the audio was not the same as it had been in the old location. I have to turn the volume up to about 70 (versus the 25 level I used to use), and it makes an annoying chirping sound at all times.
It's driving me crazy. Any help is greatly appreciated.
  • joods1 Feb 25, 2009
    THIS ALSO HAPPENS TO US AND A DRONING NOISE ESPECIALLY WHEN WATCHING A DVD AND THE PEOPLE TALK ON THE FILM
    Scholar:
  • 98 Answers
It's likely that the volume on your cable box at the new place is set much lower than your old place, so you have to turn it up.
Turning up the television too loud will cause the annoying chirping in some cases.
Try using the cable box remote, and turn up the volume on your cable box, as you turn down the volume on your television.
Posted on Mar 19, 2009
Sony bravia tv manual
I would check your setting your audio setting see if there is something u need to change in there.
Jan 10, 2014 | Televison & Video
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Surround sound hookup between my 2008 sony bravia and sony A/V surround sound receiver which is older.
the yellow on an RCA setup is a video signal not audio, so just hook up the yellow to video 1 and red /white to audio 1 or whatever number it happens to be
May 09, 2012 | Sony BRAVIA KDL-46V3000 Television
XBox Audio Problems
The red, blue and green are ONLY the Video outputs, and connect colour to colour, now, there are Two other connections, again coulor to coulor, usually red & white, that hook up to the Stereo INPUT. So you need BOTH sets to work IE: The Video & Audio. Video: Blue, Red, Green. Audio: Red & White.
Jan 20, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Lousy sound on 32" Sony Bravia
if you are have problems with in built speaker when the tv speakers are on, then connect on audio out hi fi
audio out. and make sure your speakers are on off.
Jan 16, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No sound in Sony Bravia
If the sound is not heard during tuner (channel) but is when using an AV input (DVD) then it is likely the Second Audio Program (SAP) has been engaged. Some SONYs simply have a button on the remote to toggle through choices, SAP is used primarily for second language transmission of audio. Either move to a PBS station or some other channel that specifies SAP programmimg or turn the choice (MTS in some SONY menus) back to "main" by either a remote button or in the audio menu.
Good luck.
Jun 28, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Connect cablebox/dvr to sony bravia
try yellow cable into the green y input.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/3008/~/unable-to-locate-a-yellow-video-input-on-the-tv
The problem is that av output is going into component in
If the green port doesn't work I read on another forum that
you may be able to use a dvd recorder unit to take the av in and then it can re transmit the video to an output as component out on some dvd recorders.
Apr 29, 2017 | Sony BRAVIA® DAV-HDX576WF Theater System...
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I have a 4 month old sony bravia 1080 120mhz Sony
Not common but electronics are electronics , we can have failures right out of the box. Generally Sony is reliable and I must say that you should not have to worry about cost , Is it not under warranty - its only 4 months old !!
May 13, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
515 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
