Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
How does pump assembly go back in to dishwasher gu1500xtls1
I need a diagram of how the pump assembly is supposed to go back in>
    President:
  • Whirlpool Master
  • 2,651 Answers
Are we talking about a drain pmp for a whirlpool dishwaser??? if so it simply pushes against the sump houshing and with a quarter turn clockwise "snaps" into place
Posted on Feb 23, 2009
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
HOW DO YOU CLEAN THE FILTER IN A MDBH979AWS3
This is a self cleaning dishwasher. This means the chopper inside the wash pump assembly crushes all the food waste and pushes it down the drain.
If you are having dirty dishes then the chopper is choked and needs cleaning.
You will have to open the dishwasher wash pump assembly to get there.
See this diagram for details. The chopper is item 6. I am assuming you have cleaned all the wash arms holes etc.
Mar 12, 2012 | Maytag Jetclean II MDBH945AWS Stainless...
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher will not drain out. Is it a clogged drain, bad pump or something else. Model # DU1015XTXS2, Serial # F05301668 and the Type # 575-1. Where is the drain plug located? I have not used this...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jul 05, 2011 | Whirlpool Dishwashers
Whirlpool dishwasher GU1500XTLS1 displays the number 2 and pumps out no other function works
Reset the machine. Press the control buttones in this sequence: sani-rinse,air-dry,sani-rinse,air-dary then clear! That should do it!
Nov 01, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher has become very noisy and does not clean the dishes like before it is about 4 years old
More than likely, your impeller has something lodged into it. Check the strainer (back wall, on floor) for utensils and such that may have worked their way there.
Plug your model number in @ searspartsdirect.com and you will be presented with a variety of diagrams. You want the diagram that shows how the pump is attached. You will have to remove the dishwasher from the cabinet (unless its portable) to access the pump assembly. Then check the pump. You may have also bent / broke an impeller blade. Given the age of your dishwasher, there may also be a service manual available for it as well.
Sep 27, 2010 | Kenmore Washing Machines
No button will work except "cancel" button on model # GU1500XTLS1 Have tried all suggested troubleshooting tips in manual
I have the same problem. The only temporary solution I have so far is to turn off the circuit breaker and wait between 10 & 30 minutes before resetting the breaker. The the dishwasher will work for one cycle.
Aug 27, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
I need to know how to put the pump assembly back
Go to the link provided below and under the heading "Browse Subcomponents" click on the "Pump and Motor Parts" link. I think that shows what you're looking for. Otherwise, check the other diagram links for your model on the same page.
Hope this helps!
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=6651514590&pop=flush
Jul 28, 2009 | Kenmore Dishwashers
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
115 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
