Question about Solidtek ACK-595 Keyboard, Keypad
USB k-595U solitek keyboard, switch to an AT (DIN5) connector
I have a minny k-595U keyboard that uses an USB connector to connect to a computer. However I want to be able to switch the USB cable to a AT (DIN5) connector. I have tried to use the adapters, but the keyboard still does not work.
When I have the keyboard connect with the correct adapters going to AT (DIN5) connector. I push any of the keys, and all three LEDs light up for a second. Then they shut off. The keyboard is not responding no matter what key is pressed. Is there some pins that need to be switched around inside the keyboard to make this work?
  • jakestohl Feb 17, 2009
    Well I am thinking it is a compatiablity issue.
    The only thing that is strange, is that I have another one of these keyboard k-595 that came with a AT (DIN5) connector and this works fine. I was hoping that I could cut the USB connector off, and put a AT (DIN5) connector and that the keyboard would work. However, I am not succeful at this.
    Mike,
    Thanks for you help. Solidtek doesn't have any drivers that you can download off there site. I will keep on trying to see if i can come up with anything, but again, thanks for you help
  • 3,051 Answers
Hi there:
when you installed the keyboard was the computer off and did it show a new hardware found when you turned on the computer it should have and have you tried it on a nothere computer also cause it may be a compatiablity issue here
Posted on Feb 16, 2009
  • 1 more comment
  • Michael Thomas
    Michael Thomas Feb 17, 2009
    Hi there again :
    well i am almost certain that it is a compatibility issue The reason i say this i tried to use my neighbors wireless just to see what would happen and it had the exact same thing happen on my dell i was able to load the cd rom for the keyboard and all of the lights did the same thing just like you said bit nothing happned when i pressed any of the keys so i read the manual and it did say that it was not compatiable with certain models and to contact the manufacture ofthe keyboard for support I am sorry that u are having this problem
  • Michael Thomas
    hi there again one thing that u may also want to do is try going to the website for the keyboard and see if there is any updated drivers for the keyboard that may help you with the compatiability issue that u are having ok best regards mike
  • Michael Thomas
    hi there again one more thing if you go to the device manager is there the original keyboard showing there cause you may want to try to uninstall that if it is there and see if the wireless keyboard will now work for you . best regards mike
Hello, Is there a print screen on the Mini keyboard ack-595u ?
if you have it and can't see it then perhaps it doesn't but ctrl and p does the same thing
Feb 27, 2015 | Solidtek ACK-595U USB Mini Keyboard with...
Cantusekeyboard
You should be a little bit more specific. But since you were not, I will try to be more specific about this.
First thing to know is that connecting keyboard and mouse to the computer will always work, no matter what. Meaning that once you connect either one, they will always work. Here are some things to try:
1. Check to make sure that the connector used for the computer is fine, its not broken or bent in the connecter. Check both the computer slot and the connector itself.
2. Make sure that the batteries are new if its wireless.
3. If mouse and keyboard use a separate connectors, and you know that mouse works. Try unplugging the mouse and connecting the keyboard in the same slot.
4. Try a different USB slot in the computer
5. Try a different keyboard all together
6. Make sure there are no off switches on the keyboard that might be in the off position.
I hope this helps.
Oct 17, 2012 | Acer Aspire One PC Notebook
I do not have same connection as old keyboard. Old one is round,new one is flat
You can go to any store with an Electronics department such as Walmart and get an adapter to switch from usb to the old style connector. I would suggest you get yourself a card to install that gives you usb capability as all new peripherals will be usb
Aug 22, 2012 | LG Keys-U-See Keyboard
Can i use a compaq keyboard on another brand of computer
Keyboard brand is not important. The keyboard connector is your only concern. The keyboard has either the round PS/2 connector or the flat USB connector. Therefore, the computer must have a matching port for the keyboard to work.
IMPORTANT: A PS/2 keyboard must be connected BEFORE the computer is turned on. A USB KB can be connected at any time but it may take a few seconds for the computer detects it.
Please vote for my solution if it helps.
Oct 13, 2010 | Compaq Keyboard
How to connect my key bord to pc
Any "modern" keyboard either has:
* a "round" connector (first used by the IBM 'PS/2' line of computers, 30-some years ago)
* a "flat" USB connector
* no connector at all, because it is a "wireless" keyboard, communicating wirelessly to a "receiver" that has either the 'PS/2' connector or the USB connector.
So, "how to connect" depends on which connector your keyboard has, and what sockets your motherboard has.
Sep 30, 2010 | Computers & Internet
Keyboard and mouse problems on presario 2100... keyboard is DEAD and mouse inop. The power on/off works.
hehehehe i saw this one lots a few years back, the keyboard and mouse connectors switched if the small round din5 pin type. else check to see if your bios has the USB all on. Also, chk your power conservation settings make sure these items WAKE UP after timeout reached
Nov 22, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Sprint aircard 595U to belkin router model no# F5D7230-4
Try connecting the sprint card to your router's internet port. You will need a usb-to-ethernet adaptor, along with a networking patch cable, to connect the sprint card to the router.
Then either connect to the router with your two computers using cables, or wireless. If using wireless, you will need wireless adaptors for each of your computers, preferrably Belkin brand to ensure compatibity.
Apr 10, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Keyboaard stops talking to cpu
Hi
Two questions spring to mind what type of keyboard do you have IE wire free or wired if wire free you may need to replace your bateries for your keyboard failing that go to my computer  and left click your way to device maniger check the propitys section of your key board this may help you finding whats rong as they have a trouble shooting  section there
Oct 23, 2007 | Solid Year Solidtek ACK 595U (ACK-595U)...
Solidtek ACK-595 Keyboard, Keypad Logo
208 people viewed this question
Top Solidtek Computers & Internet Experts
Mike
ray gallant
jamulder513
Are you a Solidtek Computer and Internet Expert? Answer questions, earn points and help others
