Question about Ricoh Aficio SP-C210SF Printer
Finisher Installation for Ricoh 2051
I would like to be able to hole-punch and staple when I send a print job to the printer but it says the finisher needed wasn't installed. Which disc is that on? The manuals are useless.
  • 2 more comments
  • ashleya164 Feb 16, 2009
    It has the capability to hole punch and staple. I actually resolved this issue on my own a little while ago. Thank you tho!
  • ashleya164 Feb 17, 2009
    I had to go into the printer's properties. Under the Accessories tab, if the copy tray is checked, you can't use any of the finisher options. If you uncheck the copy tray, you can now choose booklet finisher (which allows stapling and punching) or the other finisher options.
  • Thomas F. Schneider May 11, 2010
    Please share with us how you resolved it.
    This may sound foolish but; Is their a hole punch and stapler installed onto the printer?
  • 15 Answers
Open the properties of the print driver and click on the accessories tab. from there you can check off the accessories you have. if you are not sure which finisher to check off, print a configuration page from the machine and the kind of finisher will be somewhere on the top of the page
Posted on Mar 01, 2009
Why can I print a test page out but with regular printing it jams and gives c-1182 error
Finisher motor issue, remove the finisher/and unplug does it work?
what are you printing are you using staple or hole punch try printing single sheet of paper.
Jul 08, 2014 | Konica Minolta bizhub C250 All-In-One...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
What is a finisher
A finisher is also called a sorter. In the days of analog copiers they were more important because of the way the copy process was but not so much in the days of digital copiers.
The finisher in the days of analog copiers is what allowed you to make multiple sets of a document and have them come out (sorted also called colated) page one through one hundred or however many pages were in the document. In today's digital world a copier can do that with out a finisher.
So why would anyone need a finisher know you must ask; well a finisher can also be used to staple or 2 and 3 hole punch your documents depending on the finisher you purchase.
I hope this was helpful,
Shawn
Nov 28, 2010 | Kyocera Mita KYOCERA/MITA - BOOKLET...
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Jan 20, 2010 | Ricoh Aficio 1035 Copier
I have a gestetner dsc460 copier. I am going to
okay your machine has the finisher option and punch option? if so when you go to print click file, then print. when your window opens for the printers select the gestetner. then choose properties. then choose printing prfeerences. then choose punch
Dec 31, 2009 | Gestetner DSc460 Copier
What does "attach finisher to main unit" mean?
the finisher is the unit that staples, collates, punches, staples. it is to the left of the copier and slides away. when it is slide away the copier will show the message. theer is an interlock switch that tells the machine it is against it. your switch could be bad. more likely the peg or arm is bent and not engaging the switch. should be an easy fix.
Dec 26, 2009 | Canon imageRUNNER 5020 Copier
Docu color 252 fault code 012-324 ???? Bill
HERE is the manual for your unit.
HERE is the online support page.
THESE are all the available documents for your Copier
Your error code 012-324 is not listed in any documentation.
Is there something it is doing/not doing when this error comes up?
Their customer service will help you with the error code.
Please call 1-890-925-050 and have your 10 digit serial # available.
Thank you for Using FixYa!
Jan 20, 2009 | Xerox DocuColor 12 Color Copier
Mac user help!
On the windows control panel for the printer is an advenced settings features that allows you to tell it what trays you have, what finisher you have, and what options you have on your finisher (stapler or hole punch). Do you see a similar option in the Mac controls?
If not, let me know and I'll look them up in the manual.
Nov 05, 2008 | Konica Minolta bizhub C351 All-In-One...
Finisher keeps acumilating print jobs assuming they are not separte ones.
It is possible that the hard drive in the copier is about to fail. Has it gotten worse??
Mar 15, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio SP-C210SF Printer Logo
7,804 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
