Question about Sub-Zero 690 Side by Side Refrigerator
"service" light flashes but will stop for awhile when the icemaker is turned off and back on again.
  • Anonymous Mar 22, 2009
    i have an EC error and a service sign, the rubber around the door is hot and i cannot start the fridge.
  • Anonymous May 04, 2009
    service light flashes and rubber seal around door is so hot you can
    barely touch it and freezer is not very cold
    Sniper:
  • 50 Answers
If the problem occurs when the icemaker is working?lift up the overflow gizmo over the tray that should shut the icemaker off for as long as you want. is this a newappliance? if it is check to see that the icemaker is not connected to hot water which could the light to flash good luck
Posted on Mar 13, 2009
Icemaker starts then stops
The drop sensor is faulty, fooling the machine that the ice has harvested so it restarts. Eventually you will just have a solid block of ice. Replace sensor (magnetic reed switch)
Mar 08, 2014 | U-Line Icemaker
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My icemaker motor keeps freezing up. I can take
check your ice machine to be level, most are installed level, but then the installers tilt the machine back just a bit to assist in door closure, if your ice machine is even slightly out of level, it will over fill and clogg the motor the very first ice cycle
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Intermittant loss of acceleration on my 1991 plymouth sundance
Turn key, on, off, on, off, on & leave it on (not start) & count check engine flashes. 2 digit codes, for example: flash, flash, flash, pause, flash,flash., is code 32
Mar 29, 2009 | 1991 Plymouth Sundance
Kenmore 1067667461 light on but takes forever motor turn back on??
 Providing your model does not have a digital temperature circuit board, the defrost timer likely is bad. I tried to look your model up and had a problem because I think the make and model is listed incorrectly above your post..
The defrost timer should be near the interior light behind plastic. In the plastic is a plug or a small opening the size of a pencil in diameter. When it stops again turn the black screw about an 1/8 of turn clockwise. If the compressor comes back on the defrost timer will need replaced. If it does not help, try to find the exact model number listed somewhere on the fridge, most times behind and lower right hand corner with the door open, hope this helps, Thanks Sea Breeze
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
GSS25QGTA BB side by side frig
mikethemonk If there are no ice cubes stucked in the icemaker, you have to call GE for service. Your icemaker could be guaranteed for three months only. Gendos...post back
Feb 24, 2007 | GE GSS25IFR Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
290 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
