Question about Lexmark X5470 All-In-One InkJet Printer
I HAVE THE SAME PROBLEM .Can`t receive a fax
I just can`t` receive a fax .Sometime the power will just go off on it also.This thing is a pcs of ****.
  • heartlandp Feb 16, 2009
    I have a brother mfc 4600 and cannot receive faxes how do i recieve
How do I put in recieve mode for faxes
Posted on Feb 16, 2009
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
HP PCS 2210 all in one printer/FAX.
ok..unplug from power, and let it rest for around 20 min..then unplug from computer, restart and see if you get a menu panel display
May 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
I lose PC's internet connection when faxing with MX860 on network
Yeah look like you have dsl and in that case you need a filter to go on that line so it will filter out you dsl connection so the data will pass threw.
I has two plugs one for you dsl modem and one for you fax or voice...
if you have one of these make sure there on all lines even the fax line, if you do have one then it needs to be changed out as it is bad.
Thanks please do not forget to rate my answer and leave feedback
May 13, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cant receive a fax now . Only thing that has
The new phone change is exactly what's effecting your fax receiver, plus, the automatic answer feature takes over before the printers fax answerer can pick. I'm assuming that you can fax out. You need to check the operators book of the telephone to see what settings need changed to add a fax machine. (four-in-one)
Dec 01, 2009 | Brother MFC-5440CN All-In-One InkJet...
Can't send nor receive faxes w/my HP6310. It says shutting down.
Try to reset the device. # and 3 simualtenusly.
#6 is a partial reset
#9 is a full reset
May 06, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax feature in HP PCS 950
Try switching the dialing mode to "Pulse" and lowering the baud rate for the printer.
May 02, 2008 | HP PSC 950 All-In-One InkJet Printer
Panasonic KX-FL501
90 percent of the time that is a phone line issue.
But, first thing to look at is see if someone has removed the phone line and placed the line into the extension of phone jack and not the one marked "line"
You may simply need to replace the phone line between the machine and jack.
Yes you may hear a dial tone, etc etc, but you are losing one of 3 things. Either some of the phone line voltage, phone line current or what is called decibel loss.
When you send, you make the phone connection like lifting the phone off the receiver, but the signal to receive must be strong enough for it to key the fax board modem to receive.
If you have another device plugged in on the same phone line. Try removig that item, ex, an answering maching, Credit card machine etc and see if it is interfering with receiving also.
There is a high percentage the phone line is the issue.
Some things to check on the machine itself. Make sure Junk Fax setting is OFF, Make sure ECM ( error correction mode) is ON. Make sure Secure Receive is OFF and manual receive is OFF. Those will be in your machine setups.
The Junk fax setting will stop almost all incomming faxes.
It is less likely a software corruption issue. But that is remotely possible.
Let me know please, Some other obsecure things that can cause this. But I think you will find one of the posted things will resolve your issue.
Mar 04, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Lexmark X5470 All-In-One InkJet Printer Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
