Question about HP LaserJet 3055 All-In-One Printer
Unable to fax or receive faxes
I disconnected the printer while painting the office. Upon reconnecting the printer, it will not fax out or receive faxes. When I call the fax number it only rings busy. HELP
  • jay_mooring Feb 17, 2009
    fax will send very slowly and sometimes will not go through?
  • Paul schanzer May 11, 2010
    try to connect regular analog phone to the line at wall outlet to verify if ok - try to make a call and receive. If you are getting a busy, try without any device connected.
    Problem Solver:
  • 5 Answers
Check the cables, check the machine status. Some of them are turning on the "Waiting" status when you disconnect them and go back to "Online" only by manual settings.
Actually, I would recommend you to stop using faxing machine at all. Try to use online faxing - it's much more comfy. Just to try you can use Popfax.com Easter promo today - the last day and you can receive 33% discount. Practically free)
Posted on Apr 30, 2013
    Genius:
  • 2,120 Answers
Make sure the phone cord is hooked to the LINE OR FAX port.
Posted on Feb 17, 2009
Xerox Phaser 3200MFP
you have to set the fax receive mode to fax or ans/Fax.
Is there a toner low indication?
try to reconnect telephone cable
Memory can be to full, clear some data
May 16, 2013 | Xerox Phaser 3200MFP/N Laser Printer
Canon printer 5440 "unable to print see troubleshooting routine maintenance manual" - message in led window
Open the scanner cover and remove any
foreign obstacles from inside the MFC. If the
error message continues, please follow the
steps below before disconnecting the MFC so
you will not lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all
faxes), and then reconnect it.
Check whether the MFC has faxes in the
memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
OR
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
OR
You can forward the faxes to your PC. Please
see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1.
You can move the faxes from your MFC’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and
then press Menu/Set.
The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
OR
To keep all faxes in the MFC’s memory,
press 2.
4. After the faxes are transferred, disconnect
(For details see Using Brother PC-FAX
software
on page 5-1 in Software User’s
Guide on the CD-ROM.)
These steps is on user manual.
Jan 16, 2010 | Brother MFC-5440 Printer
I'm unable to receive faxes on my 9420CN . I've followed the manual for receiving faxes, I had a phone technician check my phone line and am still unable to receive faxes.
Most  likely your phone line is digital. You need an analog line. You can try to call from the fax machine simply by dialing your cell/office number and try to call it back
Jun 12, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hi my canon mx310 will not fax any ideas
disconnect all equipments using the phone line (everything)
connect the fax directly to a wall jack (a working one)
Send a one page black and white text fax to 1-888-473-2963
When your fax is received by the Test Fax Service, a return fax will be generated to you within five minutes confirming that fax was received. This verifies that you can both send and receive a fax with your fax machine.
Nov 25, 2008 | Canon MX310 Office All-In-One Printer
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Error message
I can't find the "50" as part of the "Unable to print" error. Usually when you get "Unable to print", it means there's a torn piece of paper, paperclip, some foreign object in the machine somewhere. Check under the scanner lid and inside the machine, look thoroughly; you may find a piece of paper blocking a sensor. If the error message continues, follow these steps before disconnecting the MFC so you won't lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in memory: 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1. Let me know if it helps!
Oct 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
230 people viewed this question
Ben Johnson
