Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing
I have a cannon ip 3000 i have installed a new ink cartridge but the printer is still not printing. The printer seems to feed the paper through properly but when the paper comes out there is nothing printed on the paper.
Any help would be great.
  • quay2003 Apr 10, 2009
    I installed a new magenta cartridge and now only the magenta is printing.
  • Anonymous May 17, 2009
    printer not printing. the paper feeds and the printer sounds like it is printing but the pages are blank
    Problem Solver:
  • 13 Answers
Find the maintance section of your print driver display ( far right of the display ) should see a maintance tab.
do a cleaning cycle or a deep cleaning cycle and see what happens. it should start printing.
if necessary make up a solid single color block on a windows word doc using the squares make them no line perimiters and do a black blue red and yellow about 1/2 inch tall and 7 inches wide
as a test pattern. the color that doesnt print is clogged
in the future try not to let the inks run completly dry before they are replaced.
if that doesn't help use isoprople alcohol 91proof on a cotton swab or clean cloth and let the print head soak in it for 5 minutes and try again.
Posted on Feb 21, 2009
Printer quit printing
my black cartridge is not printing it has ink
Feb 05, 2010 | Cannon i70 Printer
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
Installed printer will not print
I found a vista driver for a Pixma ip 2600 and downloaded it. My printer now works but the black ink doesn't. Don't know if it's a driver issue or otherwise. It might be worth a try for you. There are no available vista drivers for the ip3000.
Aug 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Magenta red will not print red, prints, yellow, I have tried 3 new ink cartridges for the PixmaIP6000D. Problem haappened when my Dell computer drive burned and had to install new drive. Running Windows...
Try unistalling the printer drivers and reinstall the drivers...here's a link in case you cannot locate your driver disk...
http://www.download.com/BJ-Printer-Driver-Canon-Pixma-iP6000D/3000-2116_4-10556279.html
If it still doesn't work, try cleaning the contacts between the color cartridge and the printer... Otherwise, your printer needs repair or replacement.
Nov 29, 2008 | Cannon Office Equipment & Supplies
Ip 1200 Pixma Cannon Printer Cartridge Installation Problem
i want to download the driner of canon pixma iP200
Oct 11, 2008 | Office Equipment & Supplies
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Pixma mp500
  • Replace a new Canon ink cartridge as it could be due to the unique features that Canon has build on their ink cartridge not done properly which resulted to be faulty. Report the issue to Canon if your existing ink cartridge is not from other 3rd party band, Canon should be able to do 1 to 1 exchange once confirmed that it is their ink cartridge problem. Cannon has build the unique feature to prevent users from misusing 3rd party ink cartridge on their printer.
  • Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  • Or missing pin has dropped off from the print-head which causes the printer not able to read the ink cartridge, printer needs to be serviced.
  • (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
Nov 25, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
336 people viewed this question
old marine
old marine
