Question about Tilia Kitchen Appliances - Others
Tillia Foodsaver VAC 370 won't stop vaccuming to seal
I can't find my manual and it's no longer available now at foodsaver.com, so I'm at a loss for what to do. This Foodsaver has no problem sealing when it's in Seal Only mode. It has no problem vacuuming when it's in Vacuum & Seal mode, except it never stops vacuuming. I can lift up, then push back down to seal, but of course some air gets in. I’ve cleaned everywhere I can, but nothing has fixed it yet. Any help will be appreciated.
  • warddj Mar 15, 2009
    We tried, but broke it when trying to remove a vacuum hose. Oh well. We've gotten a good 5 years of use out of it. BTW, there was no adjustment screw on the back. The only screws we found were the ones on the bottom.
    Problem Solver:
  • 11 Answers
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Posted on Jun 25, 2009
    President:
  • 2,976 Answers
I had to take mine apart and clean the vacuum line out. It got tiny amounts of liquid in it over time and did the same thing. Before you take it apart, try setting the adjustment screw on the back. It's for altitude but, a slight turn could get you the results you need.
Posted on Feb 18, 2009
My Foodsaver Vac 370 wasn't working at all. I took it apart to find the little plastic barbs for the hoses broken off in two places. I glued them back into place with Crazy Glue, which worked. This gave it suction, but it still wasn't sealing. I added a momentary switch across the contacts on the vaccumm switch. Whether this worked, or perhaps the original solder was "cold joints," I don't know. All I know for sure is that it works perfectly for me now.
Posted on Oct 13, 2011
I have a tilia foodsaver mdel # 204029 --don't have a owner manual and can figure out how to pull a vaccuum
The Quick Start Guide for the FoodSaver V420/Mini Plus is available here:
http://www.foodsaver.com/Manuals/MANUALS/FSMiniPlus_V420QuickStart_3_44.pdf
The guide had complete instructions on how to use.
You may wan to to browse the website so you are familar with other available resources:
http://www.foodsaver.com/Support.aspx
Apr 26, 2011 | Tilia FoodSaver VAC420
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
I have a foodsaver and it sucks the air out but won't seal. What do I do? We're trying to save some frozen fish and it just sucks and sucks but doesn't stop or seal. Any ideas?
The bag is wrinkled or the gaskets are leaky, it has to pull down to a set vacuum in order to shut off and heat the strip to seal the bag. For the right now dilemma try pressing down on the lid while it's vacuuming and start looking for gaskets at foodsaver.com
May 29, 2010 | Tilia FoodSaver V2240
How do I turn on my tillia foodsaver my friend lent to me?
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Sep 28, 2009 | Tilia FoodSaver V2240
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
the function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Jul 13, 2009 | Tilia FoodSaver V2240
Find a replacement light bulb for the foodsaver vaccuum sealer
Foodsaver has a toll free number that you might call to see if they can provide the part. 877-777-8042 is what is listed.
Apr 25, 2017 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
3,820 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Tim Doolittle
Tim Doolittle
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
