Question about Casio Parts Cash Register PC Desktop
Where can I buy parts for Casio T2000A?
(take up wheel)
  • 737 Answers
Hi.
If you need a takeup reel, you will need to phone a Casio dealer in your area. Just look them up in the phone book.
Mark
Posted on Feb 17, 2009
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
I have a 2002 Yukon Denali and I was wanted to know, how do u change the bulb in the steering wheel?
Steering Wheel Control Switch Assembly Replacement Removal Procedure
  1. Remove the steering wheel. Refer to Steering Wheel Replacement .
  2. Remove the horn switch from the steering wheel.
  3. Remove the steering wheel shroud retaining screws from the back of the steering wheel.
  4. Remove the steering wheel shroud from the steering wheel.
  5. Remove the steering wheel control switch mounting screws.
  6. Disconnect the steering wheel control switch (2) electrical connector (1).
  7. Remove the steering wheel control switch from the steering wheel.
Steering Wheel Replacement Tools Required J 1859-A Steering Wheel Puller
Removal Procedure
  1. Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  2. Remove the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  3. Remove the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  4. Make an alignment mark in order to note the relationship of the steering wheel to the steering shaft.
  5. Remove the steering wheel nut.
  6. Remove the steering wheel, using the J 1859-A .
Installation Procedure
Oct 04, 2010 | 1995 GMC Yukon
Ok i need to know how to assemble the steering wheel
Steering Wheel Removal & Installation Special Service Tools (SST) Required:
  • J1859-A Steering Wheel Puller
  • J42578 Steering Wheel Puller Legs
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Place the ignition into the OFF position.
  3. Perform the SIR System Disabling procedure.
  4. Remove the inflator module
  5. Scribe an alignment mark onto the steering wheel hub in line with the mark on the steering shaft.
  6. Loosen the steering wheel nut.
  7. Position the steering wheel nut flush with the end of the steering column shaft.
  8. Loosen the steering wheel using the J1859-A SST.
  9. Remove or disconnect the following:
    • The steering wheel controls electrical connector (if equipped)
    • The horn switch lead from the steering hub
    • The steering wheel nut
    • The steering wheel from the steering shaft
    • The steering wheel controls and the steering wheel controls harness from the steering wheel (if equipped)
To Install:
  1. Install or connect the following:
    • The steering wheel controls and the steering wheel controls harness to the steering wheel (if equipped)
    • The SIR connector properly routed through the steering wheel
    • The mark on the steering wheel with the mark on the steering shaft
    • The steering wheel CAUTION
      The fastener is prevailing torque type and may only be reused if the fastener and its counterpart are clean and free from rust and the fastener develops 27 inch lbs. (3 Nm) of torque or drag against its counterpart prior to the fastener seating. If the fastener does not meet these criteria it must be replaced.
      1. Torque to: 33 ft. lbs. (45 Nm)
    • The horn switch lead to the steering hub
    • The inflator module
    • Enable the SIR system.
  2. Ensure that the steering Wheel controls operate properly (if equipped).
  3. Ensure proper horn operation.
Jul 03, 2010 | 1997 Chevrolet Venture
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
Frt. wheel bearings 2003 h-2
2003 Hummer H2 V8-6.0L VIN U
Wheel Bearing: Service and Repair
WHEEL HUB, BEARING, AND SEAL REPLACEMENT
REMOVAL PROCEDURE
NOTE: Never place vehicle on the ground with the halfshaft removed or the halfshaft nut torqued improperly. Otherwise, bearing seals may become
dislodged causing premature wear and/or damage to the hub and bearing assembly.
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Remove the tire and wheel.
3. Remove the rotor.
4. Remove the wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle.
5. Disconnect the electrical connection for the wheel speed sensor.
6. Remove the wheel driveshaft nut retaining cover.
7. Remove the wheel driveshaft assembly retaining nut and washer from the wheel driveshaft assembly.
Disengage the wheel driveshaft from the wheel hub and bearing.
8. Remove the wheel hub and bearing mounting bolts.
9. Remove the wheel hub and bearing and splash shield from the vehicle.
10. Remove the O-ring seal from the steering knuckle bore.
11. Remove the wheel speed sensor from the wheel hub and bearing.
12. Clean and inspect the O-ring seal.
13. Replace the seal it the following conditions exist:
- Nicks
- Cuts
- Dry or brittle
- Compression set
INSTALLATION PROCEDURE
1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing assembly.
2. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent.
3. Install the O-ring to the steering knuckle.
NOTE: Refer to Fastener Notice in Service Precautions.
4. Install the wheel speed sensor to the wheel hub and bearing.
Tighten
Tighten the sensor mounting bolt to 18 N.m (13 lb ft).
5. Install the wheel hub and bearing and splash shield to the vehicle.
6. Install the wheel hub and bearing mounting bolts.
Tighten
Tighten the wheel hub to knuckle bolts to 180 N.m (133 lb ft).
7. Install the nut and washer retaining the wheel drive shaft assembly to the wheel hub and bearing.
Tighten
Tighten the nut to 210 N.m (155 lb ft).
8. Connect the electrical connection for the wheel speed sensor.
9. Install the wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle.
Tighten
Tighten the bolt to 12 N.m (106 lb in).
10. Install the rotor.
11. Install the tire and wheel.
12. Lower the vehicle.
Sep 15, 2009 | 2003 Hummer H2
Economy
Any vehicle that has to drive its own wheels requires horsepower. The more wheels that require power the more energy spent. If you only require 2 wheel drive to get you along that is good. Sometimes 4 wheel drive is needed. 4 wheel drive is needed in drastic situations. Does 2 wheel drive and 4 wheel drive differ? YES The power required to drive 4 wheels is increased 5.7% as to run 2 wheels. 4 wheel drive should be used at slow speed to overcome loss of traction of 2 wheel drive.
I hope this helps Moe
Apr 24, 2009 | 2006 Jeep Grand Cherokee
We are trying to replace my rear wheel bearing. Can anyone give any ideas how to get it apart?
here is how to replace it on a 2 wheel drive please do not forget to rate and comment about your experience today. 2-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Inner wheel bearing race from the hub
    • Snapring
    • Wheel bearing outer race from the knuckle
To install:
    • Wheel bearing in to the knuckle
    • Snapring
    • Wheel hub into the wheel bearing
    • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake drum
    • Rear wheel
Apr 11, 2009 | 2005 Ford Escape
I am trying to get the wheel assembly apart to change the front bearings on a 1996 mercury villiger
http://groups.yahoo.com/group/villagerquest/
Item Part Number Description 1 — Cotter Pin 2 — Nut Retainer 3 1131 Insulator 4 3B477 Front Axle Wheel Hub Retainer 5 1195 Front Wheel Outer Bearing Retainer Washer 6 1104 Wheel Hub 7 1107 Lug Bolt 8 3K050 Snap Ring 9 3123 Front Wheel Bearing 10 2K004 Front Disc Brake Rotor Shield 11 3130 Front Wheel Knuckle
Wheel Hub, Wheel Knuckle and Wheel Bearing SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Tie Rod End Separator T85M-3395-A
Removal
  2. Remove the wheel (1007) and tire assembly.
  3. NOTE: It is not necessary to disconnect the front brake hose (2078).
    Remove the disc brake caliper (2B120) and suspend it with mechanic's wire out of the way. Refer to Section 06-03 for the removal procedure.
  4. Remove the front disc brake rotor (1125).
  5. Remove and discard the cotter pin.
  6. Remove the nut retainer and insulator.
  7. Remove the front axle wheel hub retainer (3B477) and the front wheel outer bearing retainer washer (1195).
  8. Remove and discard the cotter pin from the front suspension lower arm ball joint (3050).
  9. Loosen the front suspension lower arm ball joint nut until it contacts the front wheel driveshaft joint.
  10. Strike the front wheel knuckle with a hammer while pulling down on the front suspension lower arm (3078) until the front suspension lower arm ball joint separates from the front wheel knuckle.
  11. Remove the front suspension lower arm ball joint nut.
  12. Remove the front suspension lower arm ball joint from the front wheel knuckle.
  13. Remove and discard the cotter pin.
  14. Remove the tie rod end nut.
  15. Use Tie Rod End Separator T85M-3395-A to separate the tie rod end (3A130) from the front wheel knuckle.
  16. Remove the front brake anti-lock sensor bolt.
  17. Remove the two front shock absorber-to-front wheel knuckle nuts.
  18. Remove the two front shock absorber-to-front wheel knuckle bolts.
  19. Remove the front shock absorber (18124) from the front wheel knuckle.
  20. Use 2-Jaw Puller D80L-1002-L, or equivalent, to separate the front wheel driveshaft and joint (3B436) from the front wheel knuckle.
  21. Remove the front wheel hub, front wheel knuckle and front wheel bearing as an assembly from the vehicle.
  22. If necessary, match mark and remove the steering stop bolt and steering stop bolt jam nut from the front wheel knuckle.
Installation
  1. Position the front wheel hub, front wheel knuckle and front wheel bearing as an assembly on the front wheel driveshaft and joint.
  1. Install the front wheel knuckle into the front shock absorber.
  1. Install the two front shock absorber-to-front wheel knuckle bolts.
  1. Install the two front shock absorber-to-front wheel knuckle nuts. Tighten the front shock absorber-to-front wheel knuckle nuts to 113-123 Nm (83-91 lb-ft).
Apr 10, 2009 | 1996 Mercury Villager
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
