Question about HP OfficeJet 7310 All-In-One InkJet Printer
L7680 all in one W/big & wide dark vertical line
When I scan or copy on my L7680 I get a wide dark vertical line of different shades on the output. I get the same result when I put the original on the glass or feed it view the top document feeder. There is no problem when I print a document from the printer. It’s from the top of my page to bottom & covers over half the sheet. When a color copy is done the whole page is 3or so different colors. Any help with this?
Thanks People!
  • Anonymous Mar 12, 2009
    I have the same problem. Cleaning the glass is not a fix. The problem is the same on the bed and on the sheet feeder. The sheet feeder is scanned differently than the bed. My copies have one line from the top to the bottom.
  • 2,120 Answers
Open the document feeder and clean the scanner glass.
Posted on Feb 17, 2009
  • Leroy Elliott
    Leroy Elliott Feb 17, 2009
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
I have horizontal lines running thru my copies on my L7680. Checked ink cartridge and printhead status and all is ok
Hi David,
Open the Front access door. You will find 2 Printheads. Check for an option on printer screen to Replace Printheads.
Remove the Printheads, Clean the contacts with lint free cloth ( golden electrical contacts )
Place the Printhead and close the Door.
This should fix the issue.
Feb 25, 2013 | HP Officejet Pro L7680 All-In-One Printer
A black vertical line is on each copy.
Try the 6500 driver. I have seen that allow text print but no graphics. If line disappears, reinstall 7680 driver. If line comes back, contact HP about updated drivers, check their website OR try to get your money back. I have never had luck with this series of AIO.
Good luck.
Feb 08, 2010 | HP Officejet Pro L7680 All-In-One Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Black vertical line
There is a User Shading Utility on the original product CD. Browse to the CD drive and open the folder named ShadingUtility. Run the program ShadingUtility.exe the password is GOSHADING (all caps, no spaces). Put a clean, white sheet of paper in the scanner (or glossy photo paper works really well), then click the Shading button.
Dec 13, 2007 | Panasonic KV S2026C Path-Through Scanner
HP OfficeJet 7310 All-In-One InkJet Printer Logo
168 people viewed this question
Ben Johnson
