Question about Honeywell Programmable Thermostat Heater
Thermostat wiring what do i do with the blue wire? and where does the red one go. do i leave the jump wire in?
  • 51 Answers
Thermostat wiring depends on which thermostat you are using. The blue wire is typically used for the 24v common. The red is your 24v power. If you have one transformer you will jump RC and RH.
Posted on Feb 17, 2009
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Air conditioning condensor will not run from thermostat have to go outside remve covers and jump thermostat connection . Then runs fine and cycles problem is intermitant
If it was me I would make sure the weed wacker hadnt attacked those wires as they leave the area leaving the house making their way to your condensing unit. Next, follow those wires back to your furnace control terminal area. Blower vibration can cause those little wires to break over time. Take care not to cause a break. Next, pull the thermostat off its base wall mount and jumper the red and the yellow wire, sometimes there is a blue color wire instead of yellow. If the unit outside comes on after this trick, make sure rc and rh are jumpered together on the thermostat terminal base and if they are then its your thermostat. One last thing, if someone has changed that thermostat since last cooling season, the thermostat wiring should be red to r terminal, white to w, green to g, blue or yellow to y terminal. Again rc and rh are usually jumpered. There are exceptions and at the very least see that the red wire is under the rc terminal.
Jun 03, 2012 | Bryant Heating & Cooling
I installed a Honeywell TH5220d 1029 thermostat on a American Standard AC/Heat pump and the install and setup went fine. It cooles for about and hour and quit. I found the 5 amp fuse at the furnace...
Red wire to R on thermostat red on furnace and red on heat pump Same with white except w1 on thermostat. Blue to common on thermostat common of furnace (probably brown but will be marked) and blue to common on heat pump. yellow to Y on thermostat and straight to heat pump. Orange to O on thermostat and straight to heat pump. If wired correctly with no shorts fuse problem should be solved. commonly people leave enough wire exposed inside the t-stat for wires to short together. This will blow the fuse. Hope this helps. I understand the frustration.
Jun 27, 2010 | Heating & Cooling
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
I am trying to hook up a Hunter 44260 t-stat. The old one(not sure of model) has the following hookup. White-O Terminal Green-G Terminal Red-RC Terminal Yellow-Y Terminal then jumped to W Terminal...
Here is some basic info to help you. On the thermostat the letters mean... G is for your blower fan, and is usually green, Rc and Rh are power for the heating and cooling circuit (24v) and are usually red; Y (or in this case Y/O) is power to the cooling contactor (outside the house) and is usually yellow, and W (or in this case W/B) is the common wire, and is usually white. It kind of sounds like the people who installed the old thermostat followed these guidelines, so your best chance is to go to the heating unit and seeing where the wires connect to. Hope this helps
Jun 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
150 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
