Question about Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum
Runs 10 - 20 seconds then quits-restarts on next trigger pull
I leave my handheld in the charger all the time. When I go to use it, it will run for a few seconds, then quite, I re-squeeze the trigger, and it starts again...sounds like full volume..but quits again...Have to do this about 10 times to clean my car mat.
  • Anonymous Mar 12, 2009
    Mine does the same thing. After I tried cleaning the filter this seemed to start happening. Did you ever fix the problem?
  • dcarr744 May 01, 2009
    My DC16 only runs for 2-3 seconds, so you cannot clean ANYTHING.  I also leave it on the charger all the time, which cannot be wrong as it is designed that the charger is also the "home" for the vac.
  • 121 Answers
Check battery maybe is old or not correctly charged.
Posted on Feb 16, 2009
When I press the trigger the green light comes on but motor does not
Hi Perry, it's Jack at Dyson.
If the green light comes on when your DC35's trigger is pulled, but the machine does not run, this would usually signal that the battery has no charge.
The battery should recharge fully from depleted in 3.5 hours. However if your machine has been connected to the charger for at least this long and still won't run, it could mean there's an issue with either the charger or the battery.
We're happy to talk you through some simple diagnostic checks when you have your machine to hand, to help determine which part is at fault. At your earliest opportunity, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 26, 2015 | Dyson DC35 Handheld Vacuum
DC31 not working light comes on when I pull the triger
Hi Robert, it's Jack at Dyson.
If your DC31's light comes on when you pull the trigger, but the machine itself doesn't run, it could mean that the battery needs charging. I would suggest connecting it to the charger and allowing it to recharge fully for 3.5 hours.
If you find that this doesn't resolve the issue we'd appreciate the opportunity to take you through some quick diagnostic checks. This will help us to determine what may be causing the fault. and what's needed to resolve it
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 11, 2014 | Dyson DC31 Animal Bagless Handheld...
It runs for a few seconds and cuts off.
Hi Robert,
Thank you for reaching out. I am sorry to hear you are having difficulty with your DC31. Based on the details you provided we would like walk through a few trouble shooting steps and we may be able to resolve this right over the phone.
At your convenience please call our Helpline to speak with an expert.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Dec 20, 2013 | Dyson DC31 Bagless Handheld Vacuum
Hello, I have a Dyson DC31 and she keeps shutting down. Most of the time she will shut down as fast as you pull the trigger, other times she will only power up for about 5 seconds before shutting back...
Hi there, it's Jack at Dyson.
If you need some help with your DC31 Animal handheld, we'd like to put you in touch with our experts for some diagnostic checks. Can you let me know where you're based so I can supply the correct contact details?
Oct 26, 2013 | Dyson DC31 Bagless Handheld Vacuum
DYSON DC16 STOPS & STARTS
go to http://content.dyson.com/support/
and see the complete information for troubleshooting, manual, videosetc.and fix it.
God bless you
Sep 25, 2012 | Dyson DC16 Bagless Handheld Cyclonic...
The dyson handheld cuts out almost immediately after pulling trigger, Some times runs a little longer before it stops. Keeps doing this constantly. What is problem? Thanks G
Depending on the model you have:
Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting
If that doesn't work shake your cord and see if there is a short in it.
Mar 23, 2011 | Vacuums
I have a dyson dc16 and when i pull the trigger all three lights come on but nothing happens from that point?
it needs charging . and if the lights dont light when you put it in the charger somthing is wrong with charger or battery
Oct 23, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My DC 16 will only run for a second each trigger pull. The battery is fully charged, it has plenty of suction, just wont run for more than a second. I cleaned the filters.
I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 25, 2009 | Dyson DC16 Root 6 Bagless Handheld...
I have the same problem as steve967 The dyson dc16 is fully charged, runs well for 5-10 seconds and shuts down. I wait for a second or 2 and it runs again for 5-10 seconds. This will continue for...
Dear Michael_Stad,
I am going to sound like a broken record but here is my same answer to another person with the same problem.
I have I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
1,305 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
