Question about Dell Dimension 2400 PC Desktop
Switch cablebox back to computer internet using my monitor
I am looking for an easy way to switch using my cablebox for tv viewing (using my computer monitor) back to using my computer monitor for internet use etc without having to unplug the hdmi cable from the back of the cable box each time because it takes about 1/2 hour for everything to re-boot back up again to watch tv
  • Anonymous Mar 24, 2014
    I was trying to set dual monitor mode to watch a serie on my tv flat screen and lost signal on my computer montor and I don't know how to go back to normal view, please help...
    President:
  • 2,692 Answers
If I understand correctly you are using the same cable for both. Goto radio shack or mabe one of the big discount stores and buy a Dual cable splitter and two  cables (the length that you need) One house cable will go into the splitter . Coming out of the slitter will be two cables one is to go to the cable box and the the is to go to you computer modem.
Posted on Feb 16, 2009
How do I connect my cell phone to my TV so I can use it As a monitor
One solution is to use a GoogleCast dongle and the Chrome browser. The GoogleCast device is inexpensive, relatively easy to install and reliable. You do need a tv with a hdmi port and high speed internet.
It's not a true monitor but anything you can view on Chrome you can see on your tv at very near real time.
Jun 21, 2014 | Cell Phones
Tip
Diagnosing video problems on TVs and monitors
The first thing to always check is the MENU (osd - on screen display)
Push menu or display on your tv or monitor
- if the menu is clear, the problem is in the early stages of video or outside your device (could be the source (dvd, cablebox) or input connections
- if the menu is distorted, the problem is definitely a malfunction with your device the osd is generated from (tv menu distorted = 100% tv is problem)
* you can also use other OSD signals to troubleshoot - if the volume bar or display info (input label, info bar) is clear, problems are earlier in the circuitry or outside the device. don't be fooled by translucent menus or cablebox menus.
** osd is inserted in the picture in the later stages of video processing. if your osd is distored, suspect the circuitry after the video switch. this could be a bad LVDS cable, TCON or Logic board, or even a bad lcd panel, plasma panel, crt.
on May 21, 2010 | Televison & Video
I want to use my iSymphony LCD26iH56 26" TV as a computer monitor and switch back and forth using it as a tv (connected to cable) and at other times as a Computer monitor. I have a VGA connector, but...
http://www.newegg.com/Product/Product.aspx?Item=N82E16889150004
2 HDMI, VGA, USB Port
iSymphony LC261H56 is an HDTV.
[ I'm using a 26 inch HDTV as a computer monitor right now.
An RCA EN-V L26HD31.
It's the Secondary monitor, of a dual monitor setup.
(HP 2009M 20 inch is the Primary monitor) ]
With cable company cable connected, and VGA cable from computer connected, you switch back, and forth using the Remote.
http://isymphonyproducts.com/LC26IH56.html
In the list on the right side click on -
download manuals / warranty info
Move your mouse cursor towards the bottom/middle of the page.
The ghosted out navigation guide will appear.
(Pages and view size)
Use the manual for details on using the Remote.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 24, 2012 | iSymphony LCD26iH56 26 in. TV
The TV wont come on at all, the power source is good The model # is DP19648 Sanyo Is there a reset button on TV?
d cooper, Because your unit is small screen type, You should visit YOUTUBE and view video clips of cold cathode fluorescent lamp back-lit lcd computer monitors being repaired. Your unit is subject to the same type of internal "switch-mode-power-supply/CCFL inverter ballast" circuit problems as are lcd monitors. Search terms at youtube are: "lcd monitor disassembly" and "lcd monitor repair" Then look for and view lcd tv repair video clips. Inspect your unit for "bad" (failed) electrolytic filter capacitors on the AC to DC switch mode multiple output power supply board. May have "open" fuse inside near or on the smps board. If "open fuse" the next question is why??? 12fixlouie
Nov 09, 2010 | Televison & Video
I am trying to connect my LCD Hi-def television to my computer so I can watch internet on my tv. The tv is showing "invalid signal". What is this and how do I fix it? I have the dynex DVI-D to...
You can only use your TV for viewing internet from your computer by using the TV as a PC monitor. To do this you should connect your computer to your TV using a standard VGA cable - the same as you would use to connect your computer to any other external monitor. You should note that this cable doesn't carry a sound signal so you can't use the TV speakers for sound output.
However, you can connect an HDMI cable from your computer to your TV to play media files or DVDs. This cable does carry a sound signal so you will be able to use your TV speakers here. This cable cannot be used for turning your TV into a PC monitor.
And all of above shouldn't be confused with "Internet TV". This is something totally different and requires your TV to be connected directly to the internet.
Hope this helps.
BElectric
Nov 07, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I don't have problem just a question can a tec view be used as a computer monitor? where can i get a remote
Look for a port labeled 'VGA' on the back or sides of your TV. Also, compare the ports on your TV to the port on your current PC monitor and if you see on your TV a port that matches the one on your current monitor, then you can use your TV as a PC monitor.
Sep 06, 2010 | TechView P4204TW Television
Corrupted display on LCD monitor.
Those lines on the right side show sign of damaged T-CON board, part of the LCD panel assembly, nothing you can do but getting the new LCD panel. The bright section on the screen looks like the backlight lamp reflector got out off the guide channel.
http://s807.photobucket.com/home/budm/allalbums
Sorry for bad news.
May 18, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I have a toshiba 42 inch tv model number 42RV535U we have it connected to an HD cable box and the sound will periodiclly cut out for a second and come back on it will work fine for a few seconds and do it...
Access the cablebox setup menu if possible. If it is a Motorola, you need to have the TV on and turn the cablebox off. Then press menu on the cablebox or cablebox remote. Under HDMI options, change audio output to L-PCM or PCM. This may not fix the issue, but it is a good start. Secondly, contact Toshiba for the latest firmware update for your product. Some models have had new firmware releases as late as this week for similar issues. If you still do not find resolution with these two recommendations, you should switch to component (Y/Pb/Pr) cables for your connection.
Mar 14, 2010 | Televison & Video
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
Nov 09, 2008 | Bose 3 2 1 GSX System
Dell Dimension 2400 PC Desktop Logo
93 people viewed this question
Alun Cox
