Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Lcd monitor Laptop boots but monitor displays black screen only
  • 265 Answers
This is most likely due to the fact of the usage.
Opening and closing the lid damages the connectors as the run through the hinges.
i sugguest giving HP a ring as the do a out of warrenty service for free, including postage
thanks
Posted on Feb 16, 2009
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
No display it is power is on
Hook up to external monitor .. Does the pre boot screen pop up (black and white writing at start ) ? If display runs on external monitor then your screen needs replacing usually or if you see a vague image on laptop screen then inverter or backlight is gone .. if no display on external and no pre boot screen probably the graphics chip on laptop has malfunctioned.
Dec 15, 2014 | Acer AL2021M (Silver) 20" LCD Monitor
Cq56-115dx boots to black screen
Your thinking along the right lines, first of all check the laptop using an external monitor, if you get the same problems on an external monitor it is likely to be mainboard/GPU fault. If display is fine on an external monitor I would recommend taking the laptop apart and check the LCD cable is connected correctly as the first port of call. If that doesn't cure your issues I would look at replacing the LCD cable, then maybe the screen.
Mar 18, 2014 | Compaq Presario Notebook
Toshiba laptop black screen
on boot go to setup, make sure you have display set to LCD and not external monitor, if still a problem after boot, wait for windows sound, hold function key down and press the F4 key (or what ever function key looks like it has a monitor /lcd symbol on it, mine is the F4)
Jul 08, 2012 | Toshiba C665 15.6/i5-2410/w7pr
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
It boots up and I can hear the HD ticking over but the screen remains blacked out
Hi. Connect an external monitor then power on your laptop and see if you get a display on external monitor. If display works on external but not on your internal LCD, you need to replace your LCD. I would suggest to have a qualified technician check your laptop to see if you need to replace the whole LCD assembly or just CCFL or inverter.
Jul 14, 2010 | Acer Aspire One PC Notebook
Mylaptop turns on and runs but the screen is completely black. What do I do? The power button is on and the battery charging light is on but the screen doesnt come on at all. I can hear the laptop booting...
Connect an external monitor then power up both the monitor and laptop. If you get display on external monitor, you have 3 possible problem. First, LCD is bad, Second, CFL on your LCD is bad and Third, the cable connecting your motherboard and LCD is bad or the connection is loose. It is better to replace the whole LCD assembly than to repair.
If you have external monitor but still can't get a display, your problem may be on the motherboard.
Apr 13, 2010 | Sony VAIO (PCWA-A200)
Hello my laptop the green power light comes on and the fan runs...but nothing else happens and the screen is black
It could be an issue with your LCD. To check it, connect an external monitor via RGB then boot up the laptop again. See if the laptop detects the monitor. It should automatically display on the monitor. From there point on, you can determine if the issue is the LCD.
Hope this helps.
Dec 20, 2009 | Acer Aspire 3680 Laptop
When my xps m140 laptop boot up after few minite lcd screen blak out. how to fic this?
There could either be a problem on your LCD screen, or Graphics card, to determine it. Try plugging an external monitor on your laptop and see if the display turns black also on the other monitor. If no, the problem is the LCD, but if yes (still black screen on the external monitor) it means the problem is on the graphics card.
Dec 15, 2009 | Dell Inspiron XPS M140 Notebook
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
