Question about LG KU990 Viewty
LG Viewty pc connection problems
Hi there
I am having trouble connecting my Viewty to my PC. I followed the intructions given, installed the software and connected the phone via usb.The LG PC Suite says 'U990 Ready' after i follow the connection wizard.
When I try to syncronize my phone with the pc and ACTUALLY connect it says:
Initialize connection with MS Outlook (I)
Synchronisation failed.
Fail to connect to the phone,
Please check the COM port and connect in idle screen.
This also happens when i try to connect it to the Music Manager. The phone reads
'Cannot Execute. Conflict with (Startup Wizard)'
I have tried everything i can think of (which is little). I wondered if you could help.
My computer is not a new one. Do you think it is incompatible? It has Windows XP so i assumed it would be ok.
Thanks. i have installed the lg pc suit at that was fine, and i connected the pc and the phone (with the usb) but when i click on (eg) music manager to play my songs or something my phone says disconnected
i think i have thried everything but none of it works p[lease someone help me
  • st3785 Feb 17, 2009
    Yes, My newly bought KU990R is having similar problem as mentioned.
    The PC Suite is version 2.0.2.2
    Some trouble do exist during installation as follows,
    (A)
    During ithe installing of LG CD’s process, below dialog box was prompt.
    Mentioned file “ ScanSoft PaperPort 11” was unable to be found in LG’s PC suite CD.
    Thus, only choice was cancel and abort.
    Then, PC suite installation resume.
    Able to lauch, LG PC Suite. Able to link up PC & phone using Connection wizzard (USB).
    But, below error was prompted when Synchronising was click.
    After few seconds, phone prompted “Dissconnected”
    Problem Solver:
  • 6 Answers
Hi, I just had the exact same problem..
I tried like FOREVER and I even said, if this try doesnt work; i'm giving up, and then... it finally worked.. haha :) so, this is what I did.
(dont connect your phone yet but set your phone as data service) You open the program LG pc suite, and then click connection wizard > usb > and then here, you connect the both ends of the usb.. one end on your pc and the other on your phone, and then you press next. Hopefully it says something like Com Port Number and Phone Model. You click next and finish. So, now you are connected to the phone to your pc. To get photos to your pc, you click content. images. and copy and paste to where you like (pictures in your pc) and then your done :D this also goes to other files too :D if this doesnt work, then go to your right top corner box, close all applications and go to home screen! :D
I hope this really helped because I just learned it few minutes ago and I was about to scream because I tried so many ways. Hope this helped and Good Luck :D
Posted on Jul 15, 2009
2 Suggested Answers
  • 8 Answers
SOURCE: LG Viewty pc connection problems
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Posted on Mar 08, 2009
Lg ku990i pc suite
Visit this link to download the PC software for LG KU990.
If You want to be able to see the contents of your LG Viewty on your PC, you don't have to install the software. Here's a very simple solution to that
On your Viewy go to
1.Phone Settings,
2.select Connectivity,
3.select USB connection Mode
4.set it to Mass storage, (select)
5.go back to main screen, and connect your USB to the PC
6.Your Viwety should go immediately to USB mode
7. On your PC, Go to Computer, and look for the removable driver that corresponds to the new connection (your viewty), click on the driver icon and you should be able to see your phone's content if u have a flash memory inserted on your phone.
Thanks for using Fixya.
Rating the solution is highly appreciated.
Jul 01, 2010 | LG KU990 Viewty
Trying to download my pictures from my lg ku990 to my pc but i dont have the software disc?
Most of the mobile don't need softwares to be installed for transferring pictures to computer from it. Just connect your mobile to computer and select something like "Mass storage mode/ pen drive mode", if prompted anything in your mobile. You should be getting extra pen drive like removable drives in your my computer and all your pictures can be accessed via it.
If still you couldn't succeed, then you can remove the memory card from your mobile and connect it to your computer using any memory card reader and can transfer your pictures easily.
I hope this is useful to you.
Thanks
Apr 23, 2010 | LG KU990 Viewty
Can not down load from pc using usb cable
what's the brand of the phone? normally every brand has its own way of connecting to the computer. nokia for instance uses nokia pc suite as a sync application. normally a cd with compatible software is delivered with the phone. if you don't have the cd, you can download the soft from the manufacturer's web site. install this software first and wait for the soft installer to ask you to connect the phone at the right moment to make a valid synced connection between the pc and the phone...
Apr 21, 2010 | LG KU990 Viewty
Unable to transfer files to lap top
First install the LG software on your laptop called pc suite.if you have done this then on your laptop go to control panel then system then device manager then check whether the port on which you connected your handset is working properly.If yes then go and check the settings of the pc suite you installed.Did you enable file sharing on the suite?
Jan 13, 2010 | LG KU990 Viewty
How do i transfer files from lg viewty direct to pc
you have to set the phone setting to USB mass storage before you connect.... the LG PC Suite doesnt help much
Jun 03, 2009 | LG KU990 Viewty
I cannot connect my lg viewty to my pc without it saying intialis
Did you have installed the drivers?
Run the software as administrator and by the warnig choose yes.
The fallowing software will e installed:
LG PcSuit
LG modem driver
USB modem driver
Ths take a few min.
Disconnect your LG before installing the software!!!
When its finshed you can also make an internet connction via USB or Bluethoot.
The second option go to your phone settings.
choose connctivity and the USB connection mode.
Choose Mass storage.
Now the phone will act as an extern USB Harddrive.
You can drop and drag files in the explorer of your windows.
After you finished the job you had to do put the setting back to Data service to receive the calls
etc.
I hope this will help.
May 26, 2009 | LG KU990 Viewty
Lg viewty usb connection problem
i agree had trouble in past and it seems to work that way
Jan 20, 2009 | LG KU990 Viewty
Dec 30, 2008 | LG KU990 Viewty
Can i have a copy of the LG pc suite installer?
LG Software Updater Application Download You have to install LGMobile Updater Application before download manual, software or lastest firmware for your phone.
Please check up whether your PC can support the following requirement.
  • 1GHz or higher Pentium-compatible processor
  • At least 256 MB of RAM (memory)
  • Windows 2000 (SP4 or later) or Windows XP (SP1 or SP2), Windows Vista
  • Administration rights on the PC for software installation
  • High-speed Internet connection
http://uk.lgmobile.com/web/web.product.manualSoftwareRF.laf
STEP 1Country & Language When you install the Updater application, the Country & Language settings are automatically updated according to the user's PC information. 1.jpg 2.jpg STEP 2Manual & Software search This program searches the manual and software for your phone. Select “Application, Manual & USB Driver Download…”.3.jpg Enter a value for “IMEI/ESN/MEID” or “S/N”, and then click the view button on the right. 4.jpg STEP 3Manual & Software Download Download and use the manual & software in the list. Double-click “Manual” or “software”, which is displayed in File List, and download it to your designated location.
※ N.B.: Make a note of the download location. 5.jpg
Dec 06, 2008 | LG KU990 Viewty
What you need to do is click on the top right corner of your LG Viewty phone which will show all applications running. If you have an 'Unknown' app, click on this.
The problem is that the user guide for the phone is running and you need to click on 'Unknown' and finish the tour or exit.
This will then alow you to connect to your pc;-)
Dec 22, 2007 | Cell Phones
LG KU990 Viewty Logo
603 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
