Question about Maytag PAV2300 Top Load Washer
Belt slips on the agitator pulley
You can turn the agitator by hand and then it will finish washing. Will work for a week or two then will start slipping again. Replaced the belts three weeks ago.
    President:
  • 2,976 Answers
If you have the tensioner laced backwards, it will do the exact same thing. Try pulling it the other direction and reinstalling the belt.
Posted on Feb 17, 2009
I got the same problem the belt slips on the spin cycle i have replaced the pulleys the belt and the tensioner worked well for a week then back to slipping took the whole machine apart and found dryed up grease in the top seal and on the shaft cleaned it all of put new grease on worked fine for two months today same thing again took it apart and the shaft is all gross and stickye with dryed up grease i just like to know what grease a guy should use
Posted on Feb 16, 2009
Repair a belt on a washing machine for a speedqueen
Remove the front panel by removing the three screws at the bottom of the panel and then tilting it up to unhook it at the top. Make sure the machine is disconnected from the electrical power - not just switched off but unplugged at the socket. Look for the belt between the electric motor and the main drive pulley of the agitator and also locate the belt tensioner which is a small pulley pressing against the belt under tension of a spring hook onto it. Pull and keep the tensioner away by hand to allow the removal of the belt starting at the motor pulley. Replace with the new belt by starting at the agitator pulley. Keep the tensioner pulley out of the way until the belt is fitted on both pulleys and then allow it to settle against the belt again. Do not adjust the spring tension and buy the correct belt from speed queen as it requires a graphite type belt. An ordinary vehicle v-belt will not work - repeat will not work. Replace the cover by hooking it in first at the top and then replacing the screws at the bottom.
Oct 19, 2014 | Speed Queen Clothes Washer Agitate & Spin...
Washer not agitating,spining,motor turns but will not turn belt,the belt gets hot an melts.Replaced belt,lid switch works ok, I can manually turn agitator in clock wise direction but not counter clock...
Need model number! Do a google search for a manual (just search by model number). Repair parts and some troubleshooting help at: http://www.repairclinic.com/
Jan 16, 2014 | Washing Machines
Belt slipping during agitation
Bearings are damaged or drum spider damaged .
Oct 04, 2017 | Maytag SAV5910 Top Load Washer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Belt slipped off machine
rotate pulleys while trying to reinstall belt. if belt slipped off on its own then belt is streched out. replace belt
Jun 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
G E space saver washing machine doesn't spin
Call GE answer center 1-800-626-2000 ask for tech help, Have Model # off your data plate ready,
May 09, 2009 | Washing Machines
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Pav2200 model
Sounds like a transmission problem. It's locked in agitation mode. When it is in agitation mode you can't turn the drum or move the agitator. I'd check that out.
Jan 17, 2008 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
