Samsung mL-3310D 31ppm 1200dpi Mono Laser Printer Mfr P/N ML-3310 Logo
Anonymous Posted on Feb 22, 2013
MKT-D205s reseter my samsung laser printer ML-3310D won't print after refilling it's original cartridge
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
192
Points
8
Most printer cartridge have an expiration date on them. Check to see if there is a date printed on your cartridge anywhere. If cant find one take to place like Staples and have them check the cartridge.
5 Related Answers
A
Anonymous
  • Posted on Apr 11, 2009
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Anonymous
  • Posted on Apr 19, 2009
SOURCE: i am using samsung ml
http://www.fixyourownprinter.com/forums/printer/59558
Anonymous
  • 414 Answers
  • Posted on Oct 26, 2009
SOURCE: Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Anonymous
  • Posted on Nov 01, 2009
SOURCE: samsung ml-2240 printer is not accepting refill toners please hel
my samsung printer is model ml-2240 is not accepting refill toners please help, it is showing message that toner is exuasted, even though i refilled it, plesae help?
Anonymous
  • 241 Answers
  • Posted on May 13, 2010
SOURCE: Samsung ml 1640 after refill
reset your printer using reset software or hardware module. nakshatraworld.com
New Samsung Laser Monorchrome Printer Fuse didn't reset
REPLACE THE NEW TONER CARTRIDGE OR REPLACE THE CARTRIDGE CHIP &FUSE
5helpful
2answers
I am using samsung ml-2245 when refill the toner it is acccept the toner
Perhaps you'll need to replace its lockout chip. Toner cartridges have a page counter and that needs to be reset after the cartridge has been refilled. Printing won't commence when the lockout chip has not be replaced with a compatible reset chip.
12helpful
1helpful
2answers
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
1helpful
3answers
Ml1640keeps on glowing the redlight and docs are not get printed
please dear it is problem your printer toner unite because it has a emage chip in toner it is disavle to print. it is not riffill you change this toner and buy new one original samsung toner then solve your problem
2answers
I am using samsung ml 2245 monocrom printer.. after printing 2*** print with the demo toner... it stop working and giv the error of toner exhuated..i refil the toner only single time.. plz tell me how to...
We have software to reset your printer
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
[email protected]
14helpful
4answers
It show red light.
If you wanto refill the cratridge,even after refill you'll need to reset your printer page count to 0.Download the firmware from here
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
16helpful
5answers
ML1640 not working after toner refilling
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
