Question about HP Compaq nc6000 Notebook
CONNECTIING COMPAQ LAPTOP TO MY NEW 42"LG LCD TV
When i took up the leads ( 15 pin) and sound lead to both devices the tv keeps saying no signal. all the leads are in the right places and the computer is working fine. can you help me.
  • Jason Edinger May 11, 2010
    The FN+F4 combo cycles between setups. Normally, you just have the laptop screen. Pressing it once will give you either on the external display only or on both. Pressing it again gives you the other. Pressing a third time, back to laptop only.
    President:
  • 2,992 Answers
If the cable from the laptop is connected to the TV, you've selected the VGA input and see no signal, you probably haven't enabled the laptop's VGA output connector. Somewhere on the keyboard will be a function key with a little monitor screen on it. Hold down the F or Fn key and press the monitor key and it will switch on the external monitor connector. On some monitors, the first press shuts off the laptop screen when it turns on the external connector. If yours does that, press the key a second time to turn the laptop screen back on.
Posted on Feb 16, 2009
I can't get my laptop to work on my tv
Is your graphics card compatible with your model of tv? or have you purchased the correct lead for it?
Aug 01, 2012 | Acer Aspire 7520-5185 Laptop
How to concert laptop to tv
what do you mean by concert, Do you mean connect?
If you do then you will need a 15 pin to 15 pin vga lead. Connect it to the 15 pin socket on the laptop, connect the other end to the tv's 15 pin socket if it has one. Then select PC on the tv's input source menu using the tv remote. Switch on the laptop and it should display on the tv.
May 06, 2012 | LG Computers & Internet
Connect to TV
If your laptop has the 15 pin vga socket on the side or the back and your tv has a 15 pin socket on the back then you just need a 15 male to male vga lead to connect the two together. Then select PC on you tv menu using the tv remote as the input source and switch the laptop on. Ebay has the lead you need.
May 05, 2012 | HEWLETT-PACKARD Elitebook 8460P
Streaming from pc to tv
If your Laptop and your TV has a VGA connector (D shaped socket with 15 pin holes) you can just connect the 2 together with a lead. Then whatever is streaming to the Laptop will be on the TV too.
You may have to select external screen on the laptop to select the TV screen. That can usually be done using the keyboard.
Can also be done with HDMI connectors if you have one on each device.
Feb 01, 2012 | Computers & Internet
How do i get a picture from laptop to tv i have connected r.g.b lead
I am not familiar with your tv but the normal process is to change press the button combinations on your laptop so it is outputing the picture and then change the tv input to RGB. (Most laptops use function and F7 to activate LCD output & Input button on TV remote to change to RGB mode.)
Check the VGA cable is fully connected at both ends.
Hope this helps.
Jan 31, 2012 | Acer Computers & Internet
NEED TOCONNECT MY LAPTOP TO MY BUSH IDLCD32TV HAV GOT A 15 PIN LEAD AT ONE END AND A 3 JACK PLUGS AT THE TV END WHAT DO I DO
the 15 pin goes to the computer and the 3 jacks go to the component input on the tv...you should have 1 green 1 blue and 1 red
Jul 10, 2011 | Samsung Computers & Internet
Hooked up to TV but can't get the sound leads to work. No sound from TV?? Can anyone advise please? Lorna x x x
u cant get sound from TV linked to PC.....as the PC's sound system use a RF connection...it does not have a amplifyer...the sound system travel in two formats....non-amplified and amplified....the sound sent from PC/Laptop it's already amplified...but the TV connector can receive only non-amplified signal(say from a DVD player, camcorder, music system etc)...it cant process the signal from PC/laptop......you can connect ordinary speakers ment for laptop to the sound out jack in the PC/laptop and use the TV to receive the video signal....from PC
hope this helps
Kris
Mar 01, 2011 | Acer Aspire 1642ZWLMi Notebook
I can't get my Acer 5610 Laptop to connect to my LG LCD TV. It just says no signal.... I am using a 15 Pin VGA Cable.
Once connected the LCD press Fn + F8 to switch the monitors. You cannot use both the screens at the same time.
If pressing Fn and F8 does not help Try other combinations of function keys with Fn
Sep 03, 2009 | Acer Aspire 5610-4648 Notebook
Connecting asus notebook via hdmi to LG 42 plasma tv
best option to use s-video lead ...use fn + f-key that has little square printed on it ...hp mostly fn+f4
Jan 11, 2009 | HP Pavilion dv6000z Notebook
I want to use plasma tv as external monitor
Your laptop is not set to enable the external video output.
Most likely, your laptop has a key that says "RGB/LCD" or something similar on it. This key cycles through the various video output options, enabling the laptop's LCD, the external RGB output, or both simultaneously. Most laptops require you to hold down the function key ("FN") when pressing the "RGB/LCD" key to cycle through the options.
Mar 04, 2008 | ASUS A6U Notebook
HP Compaq nc6000 Notebook Logo
640 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
