Question about HP Officejet 7210 All-In-One InkJet Printer
Cannot save scan to pdf
I am trying to scan multiple pages and save as a pdf file but the choice of pdf is not there. I had no problems on my old laptop but now with my new one, I can't save multiple pages in pdf format. I installed the HP software properly and downloaded Adobe Reader 9.0. Can someone help?
  • 1 more comment
  • brian_tay181 Feb 16, 2009
    I solved this using HP live support chat from their website. The problem was that I had installed only the Express version of the software and I needed the Full version to save scans in .pdf files.
  • Anonymous Feb 16, 2009
    what software do i need to be able to use the scanner for the hp officejet 7210
  • gregx3 May 19, 2009
    Do you need to uninstall the all in one software and then reinstall the full version?
5 Suggested Answers
  • 166 Answers
SOURCE: Can a Samsung SCX-4216F scan to pdf format?
In windows, Scx 4216f comes with Samrthru3 which does not come with pdf scan option , however you can use the newer verasion of smarthru4 which is available with scx4100/scx4521f .
All you need to do is choose Scx4216f as the device in smarthru window. and you will be able to scan in PDF format.
Will be quite simple.
Happy Scanning
Omnipresent
Posted on Oct 26, 2007
adonscott
  • 106 Answers
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Posted on Jul 04, 2008
lafalot
  • 152 Answers
SOURCE: Scans
Are you using Acrobat? If so, you can insert pages easily by using the Insert menu. It will even allow you to choose where to insert the page - first, second, last, etc.
Posted on Aug 23, 2008
SOURCE: Scanner saves multiple pages separately, need saved as one
hi,
thats very easy, i believe so ur trying to scan from the printer itself becoz that happens if u try to scan from the printer itself, instead of that use the solution center software.
if u have installed the complete software which was provided by hp, u will a icon on ur desktop called solution center, click on that and click on the scan document button on it and u get a pop window in that select the file type as PDF and click on scan at the bottom of the window and once it completes the scan, it will give a message do want to scan another page, click yes and go ahead with that........
i think i have answered ur query..............
Regards,  raj_p5983
Posted on Jan 22, 2009
  • 11 Answers
SOURCE: Scanning Multiple pages into one pdf
Typically it is possible, in advanced settings for scanning it will typically give you an option to scan multiple pages into one document.
Posted on Jun 26, 2009
How to scan multiple pages in one pdf in hp 5300c scanner
To do this will take a few steps.
1. You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
2. Scan the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scanning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document (not necessary).
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
Jul 07, 2011 | HP ScanJet 5300C Flatbed Scanner
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
I am trying to scan multiple pages and save as a pdf file but the choice of pdf is not there in the option i am using hp7200 office jet pls help
am sure there will be an option to save it as .jpg file..
save the desired files as.jpg format..
then use any of the convertion softwares to convert it into a pdf file..
one link is given below you can use it or google it..
www.topshareware.com/jpg-to-pdf-converter/.../1.htm
Mar 07, 2010 | HP Officejet 7210 All-In-One InkJet...
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I have a HP Photosmart 6180 series printer. I want to know how to scan multiple document of several pages or more and put into one file? Whenever I have scanned in the past, I have only been able to put 1...
To scan documents, you must choose the PDF scan. Need to figure out how to choose to scan as a PDF. That's in the software or scan buttons. In that setting, there should be a choice of single or multiple scans. After the scans, you choose finish and the program should show you a PDF document and then save to a folder of your choice.
Jul 30, 2009 | Epson Printer
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Scan to PDF File
You have to save your scan to PDF file type. after the system finished saving the file it will ask you again want to scan another pages. replace the page in the scanner and then click to continue.
the saving of file will on the next page of the first file name.
you're own your way.
melnavz
Jan 23, 2009 | Mustek Be@rPaw 1200CS Flatbed Scanner
Canon CanoScan LIDE 25
Use the PDF function of the CanoScan Toolbox. On the options screen for a pdf, click the drop down box next to “Save as Type:”. Select “PDF (Multiple Pages)”. This option causes CanoScan to stop after each page is scanned and ask if there is a next page or if you are finished.
May 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
HP Officejet 7210 All-In-One InkJet Printer Logo
1,212 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
