Question about Sharp AL 1631 Copier
Black stripe and white stripe on copies
My copier suddenly is making black stripes on one edge a white stripe down the middle. I notice a lot of toner buildup on the drum exactly where the stripes are. I tried cleaning the transfer wire and even gently rubbed tissue on the drum and it immediately built up again.
  • mwgdc Feb 17, 2009
    Thanks, for the advice. The funny thing is that I have a black stripe on the edge and a clear/white stripe down the middle where the toner is building up on the drum. Any advice on that?
    Problem Solver:
  • 4 Answers
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Posted on Feb 17, 2009
  • Mr Sharpy Feb 17, 2009
    The clear white stripe rules out the optics and if toner is building on the drum in that area, it would not be the drum as the area would be black and not white. The white stripe / deletion is most probably down to poor transfer or the development unit.
Panasonic dp3010 copier stripes on paper
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Good Luck!
Mar 01, 2012 | Office Equipment & Supplies
I have a 1/4" stripe
The easy way, try print with another toner cartridge (Q2612A), to avoid having to disassemble the toner cartridge.
Aug 09, 2011 | HP LaserJet 1020 Printer
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
White stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Nov 05, 2008 | Sharp AR-M205 Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Sharp AL 1631 Copier Logo
386 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
