Question about Compaq Presario Notebook
Laptop will not turn on
I go to turn the laptop on the blue lights come on for a second and go out. Laptop will not turn on.
  • tjb2thomas Feb 17, 2009
    The laptop has a internal wireless device that went bad. So i hooked up a external wireless through the usb port. laptop worked fine. Laptop sat all night off tried to turn it on the next morning and thats when the blue light on the on botton comes on and goes right out. No fans come on and nothing showes up on the screen. Hope that helps alittle more . Thank's
    Problem Solver:
  • 10 Answers
Could be useful with a bit more infomation, but if this just happened you should try to let ur computer cool down for a hour or two, if its overheated, and try turn it on again later.
Of course, if you've had this problems for several days this won't work, as I tried to express before; this is only if the problem has just appeared, because it happens to me very often.
Posted on Feb 16, 2009
  • ggaarrdd Feb 17, 2009
    Well, thanks for more infomation, but I'm sorry to say that if the fan won't work, then theres nothing I can do over internet, exept giving you the advice to go to the shop were you bought it and tell them your problem. The fan problem is a fatal error, which means the computer probably is destroyed, and theres nothing much you can do with that, so you will probably get a new one, or the money back were you bought it, because as I said before, the fan problem is a critical error.
    Though, there can be hope, I got one question: When you turn on the laptop, does the fan start a bit, and then fade quikly out, or does it not start at all?
Acer aspire 5750 won't turn on
check you fan make sure its running,,some times if its not it wont let the laptop start.
Apr 16, 2014 | Acer Aspire Computers & Internet
I have a acer aspire 5920 the amber light comes on but when I try to turn the computer in the blue light lights up then goes off and will not turn on! Pls how can I fix this??
One suggestion I could offer is to unplug the laptop and remove the battery, then proceed to hold the power button for 20 seconds and then attempt to boot the laptop again.
Sep 17, 2013 | Computers & Internet
Gateway m-6848 blue light does not turn on
Remove the ac adapter and the battery from the laptop and then press and hold the power button for 45 seconds. Now, reconnect everything and then try to turn it on.
May 28, 2012 | Gateway M-6848 PC Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My HP 6720 won't switch on. When connected to the power source, a steady blue light comes on (normal) then goes to a light blue then goes blank. If I press the 'on' button, a flashing orange light appears...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Computers & Internet
My compaq laptop doesn't turn on
At the bottom of the laptop, find and open the placing of RAM. Unplug each RAM from its bank, clean each RAM and also its bank, Plug them again in different bank. Lock your placing, now check.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
Jul 07, 2009 | HP Compaq Presario v3000z Notebook
I have a Acer aspire 6920G laptop. Now i want to turn on the side blue lights during battery mode. Because when i use the laptop in battery mode this turned off.. Any body has any idea??
at battery mode....you cannot turn on the blue lights because the battery is low at that time....due to that it will not turn on the blue at that time....if you want to turn on blue lights during battery mode when you use your laptop in battery mode then the only way is to charge your laptop when your laptop is in battery mode.....there is no other way
Sep 18, 2008 | Acer Computers & Internet
Will not turn on
Hi
do one thing remove the battery from the notebook and unplug the power cable press and hold the power button on the laptop for 10 to 15 seconds. connect the battery and power , turn on the notebook, it should work
Good luck
May 25, 2008 | Gateway Solo 5300 Notebook
Toshiba Equium A200-1VO won't turn on
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Try starting it again.
Apr 22, 2008 | Toshiba Satellite A60 Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
