Question about Apple iMac G5 Desktop
Inch wide vertical white band on my Imac screen?
Not sure why this is- its only just happened haven't moved the computer its just like a white stripe from top to bottom in the right half of the screen
anyone know how to fix this or know what is the problem
I have the same problem-a vertical white band on the right side of my computer. It seems to be before the actual screen meaning, I can see everything "behind" band but have to move my desktop info away from it to see them.
  • 55 Answers
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Posted on Feb 22, 2009
2 Suggested Answers
  • 9 Answers
SOURCE: inch wide vertical white band on my Imac screen?
I have some good news and some bad news for you. First the bad news. the LCD panel in your unit is damaged beyond what 95% of people could fix at home. what has basically happened is the very very thin signalling cables that run around the edge of the screen is damaged. your only option is to replace the panel, which can be a major hassle unless you are very comfortable with a screwdriver and have at least disassembled laptops and know what the parts are.
Bad news as well, part is about $150.
good news. most shops can do this repair for you, esp. if they deal with laptops.
I can give you the replacement info if you wish to attempt it yourself, but as i said, it can be a hard repair to do.
Mark.
Posted on Mar 07, 2009
Vertical stripes on start up
Unfortunately, vertical stripes, most likely 2 inch wide, are indicative of GPU failure. The failure is cause by the GPU slowly detaching itslef from its mountings. This process made more common by the introduction of lead free solder. IF its under warranty... take it to Apple, if not, it's doomed. There are fixes available know as 're-flows' or re-balls' .. whilst these are different processes entirely, neither is a sure fix, and neither, if it works, are guaranteed to last more than a few months.
Aug 21, 2013 | Apple iMac 27 in (MC510LLA) Mac Desktop
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Apr 26, 2010 | Planar PT1814NUV 18.1 in. Flat Panel LCD...
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Mark.
Feb 06, 2009 | Apple iMac G4 Desktop
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Apple iMac G5 Desktop Logo
1,366 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
