Question about DBX -215 Home Equalizer
I HAVE A LARGE FILE OF PICTURES IN THE OUTBOX IN OUTLOOK EXPRESS
I TRIED SENDING A LARGE FILE (53) OF PICTURES......IT STOPPED IN THE MIDDLE OF THE TRANSMISSION AND I DON'T KNOW HOW TO DELETE THIS.......I CAN NOT USE MY E-MAIL AT ALL AND NOTHING IS COMING IN AS IT SAYS IT IS STILL SENDING MAIL.......THANK YOU FOR ANY HELP YOU CAN GIVE ME...
  • 77 Answers
You can press ctrl delete and the alt key at the same time it will bring up a window depending on your current software this window and options therein are different but after doing this you are looking for a tAb labeled as task manager open this tab. after doing so in the window that appears will be a tab at the top that indicates applications processes performance and networking click the applications tab if internet explorer or your email is not there click the processes tab upon finding internet explorer right click and select end process tree. in doing so you will force all processes to stop at that time you may reopen IE or restart your computer.
Posted on Feb 18, 2009
Large file sent on Outlook Express immobilized my system
Hi
you should never even attempt to send such huge files, first of all that will take hours to send, and will most likely be rejected by the service, and as far as I know there is no email service that would allow to send such huge files, gmail, with the bigest storage I know, 7GB, has a 20MB limit on file sending.
You can't email that large file, burn it to a cd and mail it over.
Anything else?
Ekse
Jun 22, 2009 | Microsoft Outlook Express
Cannot delete email from outbox in outlook express
Plz disable ur internet, close ur outlook without sending, then open again & if sending receiving then cancel immediately, now u can delete ur e-mail from outlook.
Mar 21, 2009 | Microsoft Outlook Express
Outlook stopped getting or sending emails
Is there an email stuck in the outbox, if so go into safe mode and delete it , that is usually what happens with both outlook and outlook express, also if you tried to send an attachment that it considered to be either a threat, an .exe 'executable" file, or anything it dosen't like, it will respond in a similar action
Dec 26, 2008 | Computers & Internet
I am unable to open Outlook Express 2003
What you need to do is go to 'my computer' then right click on 'C Drive' then click on 'Search'.
Look for a folder named 'identities' - it is hidden so don't forget to mark 'search for hidden files' as well.
It should find the identities folder under application data or something like that.
Anyhow, under identities youl find a string of letters and numbers (another folder), double click and get into it all the way to outlook express... under outlook express you should see all your outlook express folder (like inbox, sent items and outbox).
If the problem is with the outbox just delete it and rerun outlook express, it should recreate that folder.
Good luck.
Hopefully it was informative enough for you to rate my response,
Thank you for using agadycom.
Dec 12, 2008 | Microsoft Office Outlook 2003 for PC
File in Outbox cannot delete or send
>lets go store location
>open outlook express>tools>options>maintenance>store folder>Copy the location
>click start >run>paste the location >Click OK
>it would open up outlook express data file with .DBX extensions
>lets make sure outlook express closed
>lets rename the outbox.dbx to outbox.old
>lets reopen outlook express> but we will loose the outbox email
Nov 05, 2008 | DBX -215 Home Equalizer
Outbox - Outlook Express 6
Hello
I havent seen that problem with Outlook Express just with Microsoft Outlook. but this solution should work with outlook express to.
here how you solv it. you need to remove the outbox file manually. remember that all your outbox files gonna be deleted.
step by step.
1.close outlook express
2. go to C:\Documents and Settings\"your user name"\Local Settings\Application Data\Identities\("alot of numbers here.->"{7850C6E6-099E-4EFD-A3F5-A88CA4FC6169}\Microsoft\Outlook Express\
* if you can find Local settings you need to show hidden files!
a. go to tools>folder options->view-> mark show hidden files and folders-> ok
3.in the map outlook express delete the outbox.dbx or move it somewhere.
4. try now to start the outlook express and the outbox should be empty.
good luck.
Sep 04, 2008 | DBX -215 Home Equalizer
Email stuck in outbox
Here's the fix if when you send an email attachment from another application it gets stuck in the Outlook Outbox...
[HKEY_CURRENT_USER\Software\Microsoft\Office\Common\MailSettings]
"StrictAccountOrder"=dword:00000001
Tooks us a long time to come up with it but great to have! It's fixed in Outlook 2007.
Bill
www.IVDesk.com
Complete hosted IT solution where we run all your applications and provide 24x7 support!
Work from any Internet connection anywhere.
Jun 18, 2008 | Microsoft Office Outlook 2003 for PC
Outlook express outbox is stuck in 'sending' mode
More than likely, you'll need to delete the outbox.dbx file located in the following location:
C:\Documents and Settings\***you user name***\Local Settings\Application Data\Identities\{***LONG SET OF NUMBERS}\Microsoft\Outlook Express
You will find the outbox.dbx in that directory.. Delete it, and you're good to go!
Jun 13, 2008 | Computers & Internet
well i guess the file you are sending its quite big into the email sending capacity.
Jun 13, 2008 | DBX -215 Home Equalizer
DBX -215 Home Equalizer Logo
93 people viewed this question
Top DBX Audio Players & Recorders Experts
Chickenwatt
Level 1 Expert
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
