Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is: a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine. or b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460. so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
can i fit the dishwasher to a hot water feed,, even though i think it supposed to be cold water...
(More)
can i fit the dishwasher to a hot water feed,, even though i think it supposed to be cold water feed???
I do not know where to put the detergent in a tempstar dishwasher. serial number 07c218965. I have...
(More)
I do not know where to put the detergent in a tempstar dishwasher. serial number 07c218965. I have the service/operational manual and it says nothing about this
Machine fills fine on first fill of the day,when machine is cold,after that it only fills for about...
(More)
Machine fills fine on first fill of the day,when machine is cold,after that it only fills for about 10 seconds and goes into wash cycle.The tank is only about one quarter full.
when we had a power outage dishwasher quit working. won't fill all the way and when manually filled...
(More)
when we had a power outage dishwasher quit working. won't fill all the way and when manually filled pump won't work but you can manually operate pump by depressing the motor relay
