Question about Maytag PYE2300AY Electric Dryer
No power to dryer was working fine no warning would not start
Model matag performa pye2300azw
  • 135 Answers
Most likely a bad fuse. There is one above the heat element, also may have one on the blower housing. Test with an ohmmeter or bypass. Hope this helps!
Posted on Feb 16, 2009
Where is the tumbler belt located on a Matag Performa Dryer model # PYE2300AYW?
www.servicematters.com/maytag_library/docs/16023083.pdf
service and repair manual above, everything is in there.
May 13, 2010 | Maytag Performa PAV2200
I have a matag performa model PYE2300AWY dryer that wont start. Jumped out the thermal fuse, and door switch still nothing. Whats next? Timmer?? HELP
Could be a burned lead, timer might be bad, or the water level switch could be bad. (Water level switch enables motor operation when the level is high enough.) Hope this gives you a good lead to check... Good luck.
Nov 28, 2009 | Dryers
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Dryer motor will not spin..motor sounds like it is sutck.
Get a putty knife, release the top by pressing the springclips between the front and top.
Then remove the front. The blower wheel may be the problem. They get loose.
Jan 04, 2009 | Maytag Performa PAV2200
Maytag performa dryer
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
My Maytag Performa electric dryer (model #PYE2300AZW) will not start. I went through the troubleshooting guide online, but did not help. Is there a built in fuse that can be checked?
thermostat common problem for this machine ( dryers in general) bad thermal fuse, a result of poor venting usually.. with a putty knife or a screw driver the main top can be "poped" open , theres a clip perhaps 3-4 inches in on either side just under main top and from panel assy, after releasing the clips the top can be flipped back to reveal the heater and fuse are. the thermal fuse is located on the right side of the heater box, and can be tested for continuity. no continuity means is blown and needs replacing. part number LA-1053( about 30 bucks). if the fuse checks out ok the n i would check the heater assy and then the thermostat also mounted right there. simple continuity check for all three, all three must have continuity.
Mar 24, 2008 | Dryers
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
324 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
