Question about Microsoft Xbox 360 Console
Fan doesn't work
Fan doesn't turn on. won't read disks.
  • Alex Keen May 11, 2010
    Is the xbox still in warrently?
    If not i can run through a few steps with you, if yours willing to open your xbox up.
    thanks
    Problem Solver:
  • 10 Answers
If the fan just won't work you should get back to the shop were you bhought it and talk to the customer service there, I'm 100% sure they will help you, and probably get you a new one if you got the ensureance.
Posted on Feb 16, 2009
  • ggaarrdd Feb 16, 2009
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
My code thing doesn't read codes how do I fix that
A code reader is only to see what codes your cars computer
may have stored
Codes don't tell you what is wrong,or what to replace
Codes are used to find a vehicle system that may have a fault
Then trouble charts are used to component test within that system
Your fan issue may not even have any related codes,just basic
auto repair,but you have to have the experience,so you need a
repair shop
Nov 18, 2012 | Cars & Trucks
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
The disk is not spinning and the band is fine
Have you checked to see if the turn for the laser is working? It won't read if the laser doesn't move. Check to make sure the teeth are good on the laser wheel and double check that it is the right position, if when you changed the belt you may have knocked something else off that is for the laser mover.
Feb 07, 2012 | Microsoft Xbox 360 Console
Power works; fan spins;light is on; promo screen works; disc won't read; disk won't spin
The most likely situation you have here is that the cd drive lens isn't reading, just because with a gamecube, it relies on that lens to detect if there is a disc inserted. Your best bet is to try and clean the lens with a que tip and some rubbing alcohol. Be gentle, only very gentle wipes back and forth in a circular motion, then dry it the same way. If that doesn't work, I can give you some tips on how to rip the thing apart and see if it is a connection inside somewhere
Sep 09, 2011 | Nintendo GameCube Console
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
1995 chevy lumina sensor went out and fan wont turn
How did you determine that the sensor failed. Did the check engine light come on? When you say that the fan won't turn, do you mean that it won't turn on and run or that you can't physically turn it by hand. To determine this, disconnect the electrical connector to the fan and try to turn it by hand. It should turn easily. If it doesn't then it must be replaced. If it does then reconnect the electrical connector to the fan and try to operate it by disconnecting the temperature sensor lead and placing a jumper wire between the terminals of the harness. turn the AC control to AC/MAX and turn the ignition key to on. If the fan runs then the problem is the sensor. If it doesn't then check the fan control relay and any related fuses. WARNING : Use extreme caution when testing the fan circuit. Never attempt to turn the fan with the electrical connector in place. The fan can operate at any time even if the engine is off.
May 14, 2011 | 1995 Chevrolet Lumina
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Microsoft Xbox 360 Console Logo
85 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
