Question about Dimplex DGWH4031 Heater
Heater noise Heater is making loud noisesDimplex DFP47658W about 1 yr old
    Problem Solver:
  • 10 Answers
Try cool it down, and give it a break (if you have used it constantly over a long time). Otherwise you could try clean it for dust, some heaters sucks alot if dust into themselves.
Last option is to get to the customer support at the store you bought it at, and tell them you're problem, they will help you gladly, and probably give you a new one if they can't fix it ;)
Posted on Feb 16, 2009
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Have a 1 year old Delonghi oil heater and has starting to make loud crackling noises when hearing up for about 5 mins.
The sound you are hearing is the metal and the oil inside expanding. When you heat metals they expand. When it cools it shrinks. I would imagine that when you turn this off it is also making these noises but you are not there to hear them like you are when you turn it on.
Sep 23, 2014 | DeLonghi Heating & Cooling
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
Loud vibration
1) What brand and type water heater? Gas or electric? Tank or tankless? Or boiler? Solar assisted? Indirect? Wood-burning? Oil-fired? etc?
2) How old is heater? Is this a new installation? Or installation that worked before and vibration is something new.
3) Or are you talking about a washing machine instead of water heater? Or hair dryer? Or GMC truck?
4) Add a comment and give more exact information from label located on side of unit, for possible assistance.
Feb 18, 2013 | Water Heaters
My water heater makes a loud popping noise. I drained the heater & it stopped for two days but has again started popping. It seems to pop when the hot water is turned on.
Sounds like an old water heater, full of rust at bottom. maybe coming to end of its life. Think new if over 7 years old. Did you replace anode rod? Probably shot also. Good Luck...
Aug 30, 2011 | Whirlpool Water Heaters
A loud puff sound on ignition
you need to have the gas valve adjusted properly.
May 12, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Feb 10, 2009 | Fasco Bradford White Hot Water Heater...
Loud Knocking
If the noise is not coming from the fan as Buffalo suggests, it is most likely the expansion and contraction of the heat exchanger. The old school way to lessen the noise of expansion is to bank the combustion chamber with a hammer. I don't recommend it today because the metal is so thin (thus all the noise) and you may damage it. You will get used to it and the noise may soften the more it is used. You will never get it to stop.
Dec 04, 2007 | Williams 3003622 Ceramic Wall Mounted...
Dimplex DGWH4031 Heater Logo
238 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
