Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
How do you remove Pump Cover on Logixx 8 washing machine?
I have a Bosch Logixx 8 Washing machine and the pump sounds like it has a metal artifact (coin? bearing?) rolling insider. The manual advises to unscrew the pump cover, and examine the pump chamber. I just cannot remove this cover. I can turn anticlockwise about 1/3 turn and that's all - it won't budge! Is there a trick to this?
  • varoshiotis Feb 17, 2009
    Hi Skrbin
    I am really grateful that you responded.
    However, as hard as I tried the cover won't budge.
    I can turn the white cover about a third turn anticlockwise, that's all. The white plastic cover seems to run as a screw in a black surround thread. When I turn 1/3 anticlockwise the white cover thread with a dimple hits the black surround and hence won't unscrew any further. I assume at that point I should be able to pull ou - but no joy. I have even tried using a pair of pliers on the cover handle - no luck. Any further advice?
    Many thanks
    Varoshiotis
  • megh_kavdika Mar 13, 2009
    Hi I have exactly same issue. I am unable to remove the filter cover. The manual says unscrew it, But I am able to move it only 1/3 anticlockwise. Mine is Bosch Logixx 8
I have a solution.You just keep turning the white knob anticlockwise. Use a pair of pliars to aid the turning keep going clockwise and anticlockwise if it gets stuck. It will rotate. Just opened my one and found a lollipop stick and a collar stiffner. Good Luck.
Posted on Dec 02, 2011
  • 121 Answers
After turn must pull out.try it.on GORENJE is like that.
Posted on Feb 16, 2009
Hey guys, i thought it pulled out too but i try with force using pliers and it did turn, and i found a lot of lint and hard plastic in there which could be causing the f 18 error. It does evently screw free so maybe use a bit more force turning, i thought i was going to break it with how hard i had to turn it.
Posted on Feb 22, 2013
  • karen beags Feb 22, 2013
    hey guys, i thought it pulled out too but i try with force using pliers and it did turn, and i found a lot of lint and hard plastic in there which could be causing the f 18 error. It does evently screw free so maybe use a bit more force turning, i thought i was going to break it with how hard i had to turn it.
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
I am getting the F-18 message on my Bosch Logixx 8 washing machine. I have to keep emptying the tube as I am unable to twist the coin filter. Reading previous notes I got a pair of pliers to try twist it...
it can be done by yourself as long as you feel comfortable in doing so as it can be a bit fiddly.
you will need to unplug the appliance, unscrew the pump housing from the cabinet, disconnect the hoses on the pump housing this will enable you to find the obstruction, remove it and subsequently unscrew the filter. then reassemble
Apr 07, 2014 | Bosch Logixx WFT 2806 Front Load...
I have a Bosch Logixx 8 1200 When i turn it on it bleeps and f 37 comes on but it is in a warm dry kitchen, the door won't lock, when I hit the temperature button twice the frost light appears ?
this a problem water level switch
Remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris that may have accumulated in the hose.
Remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the interior of the pump, and hoses.
Oct 02, 2012 | Bosch Washing Machines
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
My bosch logixx 8 sensitive front load washer is sayiing pump blocked and I can't find my manual. does anyone know how to address this problem?
I have a Bosch Logixx was bought in April 2009 and I have had this problem several times, it seems like a button or coin can block the pump, you may need to try turn machine off and pull out plug, take the drainage hose out of the holder, remove sealing cap, allow detergent solution to flow out, put the closing cap back on hose, carefully unscrew the pupm cver, see if anythings stuck there, re-insert pump cover etc. I have had to call repairmen out 3 times ( pump blocked not covered under warranty) and had pump replaced, I WOULD NOT BUY BOSCH ever againa s there after care service is rubbish and I paid $1800 for this metal junk.
Mar 09, 2011 | Bosch Washing Machines
I have a Bosch Logixx 8 washing machine and can't get the detergent solution pump cover to unscrew. It only moves about an eighth of a turn. Any suggestion how to get it to fully unscrew? Thank you.
Logixx 8 washing machine This video will show you how to change the pump washing machine
Jan 14, 2011 | Washing Machines
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
4,464 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
