Question about IBM Wheelwriter 30 Typewriter
Wont print Turns on, carriage moves L & R, but doesnt print when keys pressed ?? Thanx
  • IBM Master
  • 3,594 Answers
You probably have a broken print solenoid cap. They are available but a little tricky to install.
Posted on Feb 16, 2009
My spacebar wont move on the Brother Charger 11, (nor will the carriage move when I press any key) it seems like the shift key is stuck
The carriage lock may be on. Either on the right or left side of the carriagle (little lever) push or pull up or down.
Nov 02, 2013 | Brother Office Equipment & Supplies
Carriage wont move on underwood 565 typewriter
Belt is slipping or broken..When it sits for awhile the belt stretches.
Dec 17, 2012 | Underwood 1980s 565 Cr Electric Portable...
HP 6940 print head jammed.resume light flashing
Welcome to FixYa!
Usually print head/carriage jam is caused by paper jams or previously cleared out paper jams that left a small torn paper inside the printer.
Turn off the printer by pressing and releasing the power button.
After the printer turns off, press the power button to turn the printer on again.
The printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolved. (See instructions at the end of this article on how to print a self-test page.)
If the printer does not turn off, clear any paper jam. Press the resume button on the printer front panel. If the paper jam does not clear, continue with this procedure.
Leave the printer turned on, disconnect the power cable from the printer, and then disconnect the USB cable from the back of the printer.
Push the two latch handles on the rear access door of the printer toward each other, and then remove the door. Please refer to the image below.
Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Remove the paper carefully. It is possible to damage the printer when removing paper from the front of the printer.
Reconnect only the power cable. If the printer does not automatically turn on, turn it on by pressing the power button.
Again, the printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
If the Power light is blinking and the print carriage is still in a stalled position, continue with this procedure.
With the printer turned on, open the printer cover. The print carriage might move into the access area automatically. Allow it to move to that position.
If the print carriage does not move automatically into the access area, turn off the printer by pressing the power button.
Disconnect the power cord from the back of the printer.
Looking in through either the ink cartridge access door or the output paper tray, make sure that no obstructions under or around the print carriage are blocking it from moving.
Make sure that the print carriage can move freely across the width of the printer by gently pushing the print carriage to the left and then to the right. Clear any obstructions.
Remove and reinstall the print cartridges. Make sure that it is properly installed back.
Close the printer cover and connect back the power cord.
Print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
To print a self-test page, make sure the printer is turned on. The USB cable of the printer to the computer must be disconnected to make sure that we are isolating the printer problem.
Press and hold the Print and Cancel button at the same time. Make sure that the printer is loaded with paper. The self-test page will like the image below.
Keep me posted of your developments.
Thank you for using FixYa.
Jas247
Mar 03, 2011 | HP Deskjet 6940 InkJet Printer
How do i release the left and right margin
Move the carriage (print head) to the margin you would like to clear. When you hear the beep, hold down the [ALT] key and press [6]. Now use the backspace or the space bar to move the carriage to where you want the margin set. Now hold down [ALT] and press [7] to set the left or [8] to set the right margin.
Dec 06, 2010 | Brother ML-100 Typewriter
Paper jam cleared but wont start
  1. Unplug the power cable.
  2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
    • If the carriage moves freely, skip to Step five .
    • If the carriage does not move, continue with the next step below.
  3. Remove the print cartridges.
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Remove the rear access door.
  7. With your fingers, rotate the rollers "up" three full rotations.
  8. Push the rear access door back into the printer until it snaps firmly into place.
  9. Replace the print cartridges.
  10. Plug the power cable into the HP All-in-One.
  11. Turn the power on.
Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
  1. Reload the printer with plain paper.
  2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
CARTRIDGE JAM
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
341
Jun 22, 2008 | HP Officejet 5610 All-In-One InkJet...
MY HP DESIGNJET 500 DOESNT WORK
System Error: 86:01
Problem
Description:
Carriage-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then
try the following:
 Too much friction in the Slider Rod. Enter the Printer Information
utility and check the Scan-Axis usage. If the
percentage is close to 100%, then lubricate the Slider Rod.
 The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
 Perform the Carriage Movement test
Jun 10, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Carriage jam message
unplug the power cable without powering the printer off,
press and hold # & 6 on the printer ... while holding these two keys connect the power cord and do not release the keys till the screen turns off. press the power button to turn the printer on ... it ll go through a reset and it ll be working fine, if the issue persists let me know
thanx
May 23, 2008 | HP OfficeJet 6110 All-In-One InkJet...
IBM Wheelwriter 30 Typewriter Logo
54 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
