Question about Proscan 26LB30QD 26 in. LCD HDTV
Looking for a wall mount that fits the ProScan 26LB30QD
I can't find a wall mount that fits the 405mm X 200mm holes on the back of the TV for mounting.
  • 1 more comment
  • Anonymous Feb 18, 2009
    Trying to buy a wall mount for 26" proscan 405 mm x 200 mm -- any one have an answer ????
  • Anonymous Feb 23, 2009
    I have the same problem.... please help!!!!
  • biffmister May 07, 2009
    yeah sux ordered the same one and a recomended mount and still did not fit figures!!!!!! good luck
Http://store.videomountstore.com/ has a tool at the top of the page that gives custom mount recommendations based on the mounting holes for your specific TV. Just choose PROSCAN and 26LB30Q from the list and it will show you the mounts they have that will work for that TV.
Posted on Apr 20, 2009
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Posted on Feb 23, 2009
The DC30SJ from Walmart for the Pro Scan 26". The company sending me adapter plate for free. They guarantee all there mounts to fit. Bravo I say !!!
Posted on May 13, 2009
Go to monoprice.com and they have a selection of outstanding wall mounts that do everything but dance with you. They are very well made and most run in the 50.00 range. I just did 2 32 in LCDs with them. I am also looking to do one with the ProScan 26" from Costco.
Posted on May 10, 2009
I bought this at Circuit City Verge tilt TV mount 23" to 37" model V37TLTMT works find I have a Proscan 32" Model 32LB300Q
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Mar 10, 2011 | Televison & Video
We have no instructions for the wall mount on the entertainment system that we are using with the lg47le5400 tv. I would like to know what hole we use and what screws to mount it. we recieved no...
the wall mount should have came with the proper screws to fit the back of your tv, if the screws fit the mounting holes on your wall mount, fit the larger screws that came with your tv through and make sure its tight, if so it should work.
Jun 26, 2010 | LG 47LE5400 47 in. TV
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Dec 18, 2009 | Proscan 32LB30QD 32 in. LCD TV
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
Nov 26, 2007 | Televison & Video
Proscan 26LB30QD 26 in. LCD HDTV Logo
1,404 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
