Question about Dell Dimension C521 PC Desktop
Usb issue usb keyboard and mouse do not function at the login screen in normal boot or safe mode. devices will work if i boot into the system with erd commander
  • markillr Feb 16, 2009
    the system in question does not have a ps/2 port nor do i have an adapter to go from ps/2 fem to usb male
    Yes, its enabled. I seems like its missing drivers...its windows media center edition 2005.
  • 124 Answers
Do you have a ps/2 keyboard/mouse? Or a usb->ps/2 adapter. I'd say boot up normally and log in with the ps/2 keyboard/mouse. Then, from device manager, right click everything under USB and such and uninstall. Then right-click your computer name in the device tree and scan for changes.
Posted on Feb 16, 2009
  • Jason Edinger Feb 16, 2009
    Check in your bios for a usb enable command. Let me know if that's on/enabled.
How can i login my password protection screen, if my keyboard is nit visible?
If there is a mini-USB port or USB port plug in a keyboard to try and complete the login process.
If this a Windows 8.1 system you can enter recovery mode chose to open in safe mode first to see if the keyboard comes back. If that does not work chose to restore the system to a point before you could not access the keyboard, or just select refresh the OS to resolve the issue. Remember if you refresh you are NOT deleting your user files or settings you are just refreshing the OS. If you reset you WILL BE resetting the OS to the way it was when you first purchased the device.
Hope that helps.
5 Ways To Boot Into Safe Mode In Windows 8 1
Nov 05, 2015 | Computers & Internet
My keyboard in my revo rl100 doesn't work
Sounds like the battery in the keyboard is dead. Also make sure you have the wireless doggle that came with the keyboard and mouse plugged into the usb port. You might try plugging it into another port.
I'm thinking your keyboard is dead because of the battery or a virus has hijacked your keyboard.
Try booting up in Safe Mode to make sure it's not virus related. Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option and let it boot up. Safe Mode will look different because the icons are bigger and the screen is darker, this is normal. If your keyboard works in safe mode then you might have a virus that can't function in safe mode.
Mar 25, 2012 | Acer Revo RL100U1002 Desktop Computer...
THE KEYBOARD DOESN WORK
Keyboard not wirelessly connecting
Mar 25, 2012 | Computers & Internet
My Acer L410 continually restarts. I am tryiong to start in safe mode so I can do a system restore. The keyboard works so I can select safe mode but once I reach the login on screen neither the keyboard...
I have 2 suggestions. First, try different keyboards/mice. I've had similar problems in the past with the drivers for usb peripherals not working after updates or re-installs. usually the older and more basic a mouse/keyboard is, the more likely it is to work in this situation. if you have old mouse and keyboard jacks(the round, purple or green ones that look like s-video), use them. Second, if you are running windows 7, when you get to the boot options, don't select 'safe mode', instead look at the other options below. there should be one called 'boot without driver signature enforcement' this may allow the computer to boot normally and restore keyboard function, however, it is not a solution and if it works, it indicates that you most likely have a malware problem. after you get it to boot, immediately start a scan with a reputable anti virus program (I recomend malwarebytes http://shop.malwarebytes.org/lpa/342/4/7268/free_g.html?x-at=regGcbmd ) then use the kaspersky rootkit remover. (http://support.kaspersky.com/faq/?qid=208283363)
Aug 03, 2011 | Acer Veriton L410 Desktop - AMD Athlon 64...
PS/2 Mouse and keyboard do not work at login screen.
If would be a driver issue if it was USB. Clean the connectors in the PC. It may be an issue with internal drives. But I m pretty sure an update caused the trouble if you did so. If you find the update you can use MS website to find a solution. Or you can remove the update. It happens often. Other reasons. It may be caused by a virus as well (or bad ram). It happens rarely though. If you have connection sharing setup (a network) you can check the the other HDD for viruses (or plugging in as a slave to the other PC, but do not open the drive). Check your RAM using Computer B.
Have you tried to plug in ComputerB's Key board and Mouse? Do they work? If they do do the following after login in. Get RUN box in the Start menu. Type Eventvwr.msc and hit enter. Go to System and check for errors. If there are please list here. (Check for Application errors also.) Thanks for contacting Fixya
May 27, 2010 | Microsoft Windows XP Home Edition
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Acer Aspire 5100 Notebook Boots to Windows, but nothing works. No keyboard, no mouse, no usb or CD, no external monitor. I have an Aspire 5100 Acer Laptop that has no keyboard or mouse function period...
Try booting your computer from CD ROM with the OS CD/DVD already inserted and when prompted just try repair. If that does not work re-install the same on the same 'partition' assuming it to be C by deleting the the windows system files only. While doing so keep the internet on and immediately after the basic version of the OS is installed and the m/c boots-up for the first time, go to the official website and download the latest drivers for every component like toch-pad, keypad, display, audio, etc.(i.e. almost all the drivers)
Mar 16, 2009 | Acer Aspire 5100 Notebook
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
I have four Compaq EVO D510 computers that all have the same problem. They are used computers that were pulled out of an existing site. I have a USB mouse & keyboard connected to the computer (no...
Hi sdd555,
Restart the computer after plugging the USB keyboard into a different USB port, or remove the keyboard in Device Manager and then refresh the system to work around the issue. This will cause the device to be re-enumerated and the driver will be reloaded.
Good Luck,
Mark
Jan 13, 2009 | Compaq Evo D500 PC Desktop
Dell Dimension C521 PC Desktop Logo
230 people viewed this question
Alun Cox
