Question about Sony Handycam DCR-TRV18E Mini DV Digital Camcorder
Sony trv18e a few things don't work
Basically the nightshot light does not work even though it is ON in the menu. The focus/infinity button does not work. The volume playback cannot be heard through the external speaker on the camera although it has been recorded fine and works with headphones.
Apart from that it records and playbacks ok.
Anybody any ideas why these things don't work?
Many thanks in advance.
Karl
  • 10,594 Answers
Night shot light is "Infra Red" and you can not see it directly though camera will shoot in darkness if you slide ON Night-Shot switch.
Regarding playback volume problem, I think built-in speaker is defective ( open ) and needs to be replaced.
Let me know if you want some more info.
Posted on Feb 16, 2009
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Infinity focus isn't working anymore
ahaha.... never mind. I was dinking around with it again and turns out, infinity focus only works if facial recognition is on... why, i don't know.
Apr 10, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
Bose 321 remote control not working
You can test a remote control using these methods:-
Method 1 - If you have AM, Medium Wave radio then set the tuning off a channel and press the remote control buttons. If there is a change in sound, higher and/or lower tones the remote is working.
If not check the batteries are charged and fitted correctly.
Method 2 - If you have a digital camera with nightshot, wait until it's dark turn off the lights and turn the camera to nightshot. Aim it at the remote in the dark and focus then press the butoons. Look at the led light is there any change/flashing on the end of the led.
This will confirm it is the remote control and a replacement is required, or batteries need changing
Jan 17, 2009 | Bose RC-18S Remote Control
Menu is not working in dsc w 55 sony cybershot
This camera is eleven years old, and is probably worn out
May 02, 2017 | Sony Cyber-Shot DSC-S40 Digital Camera
Cant clear nightshot plus mode
Night Shot option can be OFF by switch at top of camera.
Jul 25, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Sony DCR-HC51
This is the solution, I would only add that it's on the top of the camera itself. Not in the digital menu or backlight button. On my older version, it's between the cassette and lens sections of the camera.
Never having used the nightshot before, my sister left me with the same quandary...
Jun 29, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Video screen is scrambled
bad tapes ive seen it before ..buy a different brand brandnew ones and give it another go.
thats why other tapes are working.
Nov 11, 2007 | Sony Handycam DCR-TRV33 Mini DV Digital...
DSC-F717 - "stucked" in nightshot mode
Yes you are right, it is more than likely the nightshot button that has shorted.
This is button is part of what we call the Switch control Block.
Phone your local Sony service Centre and ask them how much it would cost to replace the switch control block. My estimate is about a 1/5 of the original cast you paid for the camera.
Good luck.
Sep 24, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Keep on changing the focus during video capture
As you pan autofocus will try to latch onto a different focal point. Check your manual or go to the Sony Tech support team
Jul 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Handycam DCR-TRV18E Mini DV Digital Camcorder Logo
127 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
