Question about Skype IM
Proplems with out going internationl calls
Each time i dial an internationl # it says number is not correct or not in valid. I am possitive these numbers work
    Problem Solver:
  • 10 Answers
Maybe you got a outdated version of skype?
You can probably find a newer version throught google searchs like "Newest version of skype" or something like that.
You're firewall or antivirus program may be the reason for it to, they can block things like that without giving you a warning, try turning off your firewall for a minute and try to call again, if that works, turn on the firewall again and then allow "skype" accsess throught the firewall manually. I could give you more info about this to, but then I need to know what firewall system you got.
Posted on Feb 16, 2009
How can i block internationl call on nokia 1100...??what is call barrier code??
Go to the website of your service provider and you can block numbers, I know verizon does this for certain.
Feb 24, 2015 | Nokia Cell Phones
We had a new motherboard put into eee netbook. (It was less than a year old). Now we get an error message that our version of Windows is not genuine. I was told by the Geeks at Best Buy that I needed an...
If you still have the appropriate CD key (most likely on the bottom of teh netbook if bought with the OS preinstalled) call microsofts product activation line, use the automated prompts an in the prompt tell it you have the same computer, new hardware. It will give you instructions on a long numeric key to enter to re-validate your copy of windows for free.
The best way to get the phone number and to get to where you need the numbers is go to register your windows OS like normal, click on register by phone, select your region and it will give you some numbers. Dial the number according to your region and dial on your phone keypad as it asks for the numbers it shows you, then on the next screen it will give you numbers to enter and your finished. It's the easiest and most affordable way to go, so I hope this has been helpful.
Feb 03, 2011 | ASUS Computers & Internet
I cannot dial calls from contacts as +1 appears before most calls
Depending on where you are this may be OK. If you are in the US and are dialing to a US number it will work. Mobile phone systems understand about internationl numbers and the + symbol is the international access code and 1 would be US so it will work. The calls will connect as normal. If you're not in the US you haven't set up your country settings properly
Aug 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
Some phone calls cant go throw
I assume that this is a home phone issue. If so, it is possible that it is setup to dial an outside number before dialing the number that you input (like at work we dial a 7 before dialing our customers number). This will make your calls have an extra number at the beginning if it connects directly to an outside line.
Jun 10, 2009 | Panasonic Lands Phones
Can't dial abroad
how are you dialing the number on the phone, what is the number, if your are not dialing it correctly it will cause this,
i.e i believe austria is 00 + 43 + Area Code+ Tel #
and norway is 00 + 47 + Area Code+ Tel #
if you go to www.countrycodes.com this will help
Jan 01, 2009 | Lands Phones
DKT 2020 ST
The phone needs to be fowarded to voice mail. go to the phone press intercom# 604, dial the voice mail extension number , press the speed dial button, enter 16 for time then press redial
Sep 15, 2008 | Toshiba DKT-2010 Corded Phone
Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Jan 08, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Skype IM Logo
43 people viewed this question
Top SKYPE Computers & Internet Experts
Mike
brian soufane
LP
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
