Question about Sony KV-13M20 13" TV
Sony Trinitron Color TV/13M20
Only have a hand full of channels from the cable
SOURCE: Sony Trinitron Tv: Cannot get video label or channel number to go away
on your remote try hitting "tv" then info or display
Posted on Oct 26, 2007
Benimur
  • 6966 Answers
SOURCE: Sony Tuner KV-20TS27 loses signal
Either that of your tuner block is acting up. Most Sonys of this production year uses a tuner block that requires 33VDC tuning supply. It has been known for this zener to fail or the capacitor parallel to it. At times, it could just be the tuner block itself.
Should you venture a DIY, it would be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings.. It further requires familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable going this route, then perhaps your best bet would be to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
  • 4234 Answers
SOURCE: doesn't get all cable channels
With the menu set to cable signals, the autoprogram should catch all of the cable channels. The Cable Channel option allows you to use either channel 3 or 4 as the "cable" channel. This is when you have an external box that you use to tune in cable rather than the TV directly. The easiest way here is to autoprogram the TV while playing a VCR tape. That will insure that channel 3 is included.
Does the autoprogram fail?
Dan
Posted on Aug 20, 2008
spiffyrodent
  • 85 Answers
SOURCE: Channel 3 displays in upper right hand corner
press the display button
Posted on Oct 23, 2009
Samyfam
  • 379 Answers
SOURCE: No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Posted on Nov 07, 2009
Why does a Sony Trinitron when on Video 3 works fine with dish. When on channel 3, color goes to b & w, then snaps back to color. on a regular cycle ?
your converter box has a channel generator for the channel #3 and you tv has a tuner set to ch#3 that and a coax wire . every part of that system has to be working correctly to send video ,color,sound if even one part of the system is a little off you run in to problems . most likely your problem is with the converter box channel generator . contrast that to when you get the signal from your video input . with that simple system you just take video from the video board in the box and send it directly into the video board in the tv .....a lot less to go wrong .
Aug 26, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Trying to hook up Phillips DVD player and have 3 coaxial cables that need to be hooked into Sony TV and I have 14 holes for cables-help!
Don't use co-axial cables buy HQ SCART Gold Plated Ribbon cables with full 21pins then hook up the AV out of the DVD player into one of the AV in on the TV.
When you turn your player on it will autoselect the correct AV (audio visual) channel on the TV.
Feb 12, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When changing channels, sometimes the color is greenish/purple. Return to the previous channel and the color is fine. I've replaced the DVR from the cable company so I'm assuming that the problem is with...
try a dvd into input one on the tv.if this shows
good with no color problems.then call the
cable co.if you have another tv check the signal with that tv.if the cable is good then
suspect the tuner in the tv.
Jul 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv
Please resold all pins of IC001 in main board of TV. Problem will be solved.
Aug 08, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV is cutting in and out of color
My sony Trinitron TV just shows a padlock on the screan.Please help me unlock it.
Mar 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Mar 09, 2008 | Televison & Video
32" Sony Trinitron made 10/1994
Probably bad solder connections in the video processor area.
Oct 29, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-27FS120
as no sound on certain channels it means no problem in your tv though it is old. the problem is in transmission line from where you get prog. it can be adjudted manually by vol.control if low sound is there at certain channels. you can also reset once.
Sep 26, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
