Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc46d64u screen has vertical green lines
Child threw toy at screen, now it has green lines running up and down threw middle of it. What do I need to purchase to fix this problem? How much?(approx.) Where? Best Buy says 3000 to fix a 1500 TV!
Will buy new before I pay even close to that!
  • 33 Answers
Unfortunately my friend, there is not a whole lot that can be done. Sharp has a great limited warranty, but it does NOT cover ANY problems due to physical damage. Getting screens replaced often times cost more than the tv itself. Save yourself the trouble of getting pissed off at sharp because they wont help you if you decide to call and replace the tv. Good luck 2 u
Posted on Feb 19, 2009
Sharp Aquos LC46D64U Multi-colored vertical lines only, like test pattern. Volume and channel control work as well as input select. Just the picture. Have tried to reset to no avail.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 27, 2017 | Sharp Televison & Video
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
I have a 37 in sharp lcd tv. it has a black line in the middle of the screen. looks like it burnt into the screeen. is this repairable?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help.....
Jun 22, 2010 | Sharp Televison & Video
I get vertical lines running down the middle of paper
lift the lid ull see a thin **** glass make sure its very very clean
Mar 30, 2010 | Sharp AL 1631 Copier
Tv repair
A vertical line means the line is up and down in the middle of the screen. That would indicate that the vertical IC and the surrounding components are working perfectly. A vertical line as described is the result of a lack of horizontal deflection (to move the beam from side to side) Since the high voltage is obviously OK, the problem is most likely a bad solder connection in the horizontal yoke circuit. Examine the bottom of the PC board in the area of the flyback transformer, and yoke connector (has four wires Red, Blue, Green, Yellow).and the pincousion coils, capacitors, etc in between. Flexing the board in that area may cause the problem to come and go. Resulting arcing should also be visible. BE CAREFUL, as hazardous voltages are present in the circuit!
Nov 29, 2009 | Sharp 19R-M100 19" TV
Black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Sep 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Line down the middle of my sharp aquos 42 inch
first make sure it does not come from the signal. If its really from the tv and look like a darker line it can come from the lcd control unit but most of the time its a dfective lcd panel
Mar 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
671 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
