Question about Bosch 12" Compound Miter Saw 3912
Bosch Miter Saw Turned On By Itself
Our Bosch saw turned on by itself. It was plugged in however no one was near it, there was no power surge, and it hadn't been used in over an hour. We are at a loss on how this could have happened. Both the safety switch and the "on" switch work fine. No problems with the saw prior to this happening. Wondering if this has happened to anyone else?
  • David Ford
    David Ford May 11, 2010
    I work on the Bosch tools and have never heard of this, however I think to be on the safe side I would replace the switch. It could have been a buildup of dirt and arced across to complete the circuit or the trigger possibly stuck, personally I would not take that chance. You can go to Boschtools.com and find the switch and you might also send them an email explaining the problem
    President:
  • 1,996 Answers
A ghost in the machine?
That sounds like a good one for Bosch tech support. I've never heard of any saw doing that, and I bet they'd be interested to know about it...
All I can imagine is a short in the switch, some kind of power surge you weren't aware of, or a practical joke.
At any rate: Contact Bosch: http://www.boschtools.com/Service/ContactUs/Pages/default.aspx
Posted on Mar 30, 2009
Makita miter saw wontr turn on
make sure that your outlet is hot, once verfied that you have power going to the plug of the saw cord, verify that you dont have any breaks in the cord itself. once verified no issues with cord you can check for power at the switch, if there is power at the switch but not coming on, probably bad switch.
Aug 10, 2014 | Makita 10" Miter Saw LS1030N
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
The belt on my new saw started to frey after some use
It sounds like you need to replace the belt. try the following websites, they offer the saw parts:
http://www.ereplacementparts.com/bosch-5312-dualbevel-slide-miter-saw-parts-c-128_1090_157465.html
http://www.toolpartspro.com/bosch-parts/bosch-5312-parts.html
Feb 10, 2013 | Bosch 5312
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
Blade stops in middle of cut, slipping motor rpm is un changed. 10" compound sliding Bosch miter saw
Going on the information aas I read it, the blade is slipping, meaning that it is not tightened enough or a spacer in the hole in the blade is too thick. Make sure that the wall plug is pulled out before attempting any work on the blade.
Jan 16, 2011 | Bosch 10" Slide Miter Saw
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
12" Compound Miter Saw with Laser Marker - C12FCH: Electronics including the laser marker do not func...
Some lasers work off batteries. If yours does, you might want to change the battery/batteries.
May 17, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Bosch sliding miter saw, the bearings in the slide mechanism are catching making a jerky slide, have tried wd40 any ideas?
Have you tried blowing out the mechanism with a compressed air nozzle? Frequently this friction is caused not by the bearing itself but instead by debris, sawdust, etc. built up inside the base of the saw. I'd give it a good cleaning to begin with.
If that doesn't work, try applying bearing lubricant directly to the bearing races.Use an extension straw if needed so you can get to them, as this is designed to penetrate where even the reliable old wd40 may not reach. You can find this a specialty woodworking stores, as well as some well-equiped home centers.
Let us know if this works, or you've already solved the problem...
Jul 29, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 12" Compound Miter Saw 3912 Logo
158 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
